Home > General > God bless the FBH !!
Page 2 of 7 <1234567>
It doesn't matter where i leave mine, though generally i dont think its ever been below 21'c on the dial and i am an 'old skool' FFRR but it shouldn't make any odds as its just heating the interior up as best it can as most of the heat will escape when the door is opened Sad
Post #96390 5th Dec 2011 10:05pm
Andy
I must get mine sorted out. Its only ever blown cold air since I've had it. On the menu, it says "Aux ventilation" or something. Haven't got a remote, so I assume I haven't got the receiver (can't see it in the boot) 2010 MY Vogue SE TDV8 3.6 Stornoway Grey- fully loaded
Post #96404 5th Dec 2011 10:47pm
mjdronfield
How do you know if you have a FBH ?
Do you have a different option on the computer ?
If you only have the "timed" version, can you add a remote, or is that only for later vehicles ?
Cheers
Mark 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #96488 6th Dec 2011 4:23pm
rwilson
United Kingdom 2009 Range Rover Vogue TDV8 Zermatt Silver
Hi i have a tdv8 on an 09 plate, never used fbh before but have heard battery drain horror stories. Is that only applicable on newer my versions?
Post #96494 6th Dec 2011 5:09pm
Rambles
2011 Range Rover Vogue SE TDV8 Stornoway Grey
correct
as to why that is, I am mystified.
Does anyone know why the MY11 started having problems?
Post #96507 6th Dec 2011 7:11pm
tboner001
England 2014 Range Rover Autobiography SDV8 Fuji White
i had the battery change made no diff however there was a recall for a module recently that seems to be the issue , you can tell if its the problem park the car up unlock it and if you hear the fans run up inside the car that causes continuous drains every time you open the doors even if you do not even turn the ignition on. Now i have 11.5MY with no issues Smile Far to many gone...
Post #96517 6th Dec 2011 8:09pm
barrieeld
Hi guys I have FBH with a remote but ive tired pressing in the morning and although I head a fan blowing its not hot in the car and it hasn't defrosted my car? Range Rover SC 35th Anniversary 2006
Post #96593 7th Dec 2011 12:14pm
dan_uk_1984
Approx how long did it run for? It will turn off if the battery isn't at full health to avoid running it flat. Also the remote can be set to winter or summer mode I believe. In summer mode it only runs the fans to ventilate the car...
Post #96671 7th Dec 2011 7:40pm
barrieeld
It ran for about 10 mins just like the fans blowing as you described. How can I change it to winter mode? Range Rover SC 35th Anniversary 2006
Post #96692 7th Dec 2011 11:04pm
Rambles
no such thing as winter or summer mode.
Above 15 degrees ambient temperature, the system will vent only
Below 15 degrees, the FBH will heat cabin
at very cold temps, the system will pre=heat the engine
Post #96696 8th Dec 2011 12:10am
thats interesting, so in the summer you could set the timer [or if you have a remote system] to expel the hot air so it wont be to hot when you get inside..
Post #96704 8th Dec 2011 8:41am
barrieeld
So what seems to be the problem with mine then? Range Rover SC 35th Anniversary 2006
Post #96707 8th Dec 2011 9:39am
its broken.... Mr. Green
does it work with the timer.
do all the other heating controls work.
have you checked any relevant fuses.
you could try dis-connecting the battery and see if that re-boots something..
Post #96708 8th Dec 2011 9:48am
Rambles
scarey, that is correct
Post #96760 8th Dec 2011 7:35pm
dan_uk_1984
MODE
To display the current mode, press and hold the [ON] and [OFF] buttons at the same time.
If the LED shows RED the appliance is in heating mode
If the LED shows GREEN the appliance is in ventilation mode
Post #96772 8th Dec 2011 8:53pm
