Home > In Car Electronics (L322) > Indicators!
Luckyluciano
Indicators!
After fixing my wing mirror problem (passenger side wouldn't fold) I seem to have gained a different problem.
Now my front passenger side indicator doesn't work or should I say works intermittently Shocked
I have checked the bulb and that is all fine. I have also taken the door card off and checked and cleaned all the connectors. I also removed the battery to see if it needed to reset but all have failed to resolve the problem.
Please tell me it's something simple.
Cheers
Dave Range Rover Autobiography 5.0SC
Range Rover Vogue 4.4 V8 SOLD
Aston Martin V8 Vantage
Post #96628 7th Dec 2011 4:58pm
when you sorted the mirror did you maybe dislodge or bang the near side wing ..its got to be in that vicinity be it the bulb holder or the wiring to it..
Post #96630 7th Dec 2011 5:14pm
Luckyluciano
Not that I remember? I did try to follow the cable from the indicator but it just seemed to go down then I couldn't follow it anymore.
It looks like it will have to go on a diagnostic machine to see were the fault actually is. Range Rover Autobiography 5.0SC
Post #96633 7th Dec 2011 5:23pm
sure its not the bulb holder or the wiring going to said holder..
Post #96635 7th Dec 2011 5:30pm
Luckyluciano
I was until you said that Confused I will double check again tomorrow morning but I am sure it was all fine. Range Rover Autobiography 5.0SC
Post #96638 7th Dec 2011 5:34pm
Could just be a poor connection between the bulb contacts and the holder. Spray both with some non-drying contact cleanser
Post #96641 7th Dec 2011 5:51pm
Luckyluciano
I'll give it a go tomorrow morning Thumbs Up
Found a local garage with the T4 diagnostic computer. So if I can't find it in the morning will take it down to them to see if they can find it. Range Rover Autobiography 5.0SC
Post #96676 7th Dec 2011 8:03pm
Luckyluciano
Right after a good look round and testing the electric feed. I have found the problem to be the bulb housing.
I did swap over the drivers side to double check and it confirmed the bulb housing as the problem.
Got one ordered and thankfully a nice cheap easy fix Thumbs Up Range Rover Autobiography 5.0SC
Post #96714 8th Dec 2011 12:46pm
