![]() | Home > Technical (L322) > Navcoder and MKII Sat Nav? |
Looking at enabling TV in Motion using Navcoder (just because I can!) but have read somewhere that if you try this with the MkII Navigation system it will kill the Sat Nav.
jaybear Member Since: 31 May 2011 Location: Marseille Posts: 156 ![]() ![]() |
Joe 90
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35836 ![]() ![]() |
this looks interesting, recognise the members. |
Yes scarey, also found that post, but I think Dan had upgraded his sat nav ? .
Ajay(UK) Member Since: 02 Mar 2010 Location: Arundel, W. Sussex Posts: 608 ![]() ![]() ![]() |
I have just re-read the "Readme" notes in the Navcoder software I have and I cannot see anything that says it wont work on a MK3 in fact they specifically mention that it works on the earlier BMW MK2 so all should be fine |
Reformed Member Since: 09 Oct 2010 Location: South Posts: 471 ![]() ![]() |
I use navcoder.
The RR has the Mk3 nav as standard.
mk3 is cd
Well I was assuming Joe meant the standard earlier CD based nav system which is what mine is, so that's a mk3 then! Reformed |
Thanks for all your input.
Navcoder will work fine on your system - which is a mkIII.
