![]() | Home > In Car Electronics (L322) > Which aerial? |
Can you not use the factory aerial? Saves sticking a new one to the glass, u'll just need an adapter... |
going to strong can be just as bad as to week, london is on 90% power going to full in 2012, i use factory aerials and dont find any probs. V8 facelift Range Rover Autobiography 22" wheels.
tanertimur Member Since: 17 Sep 2011 Location: London Posts: 90 ![]() ![]() ![]() |
Dont the factory aerial get its power from the tv tuner,
Reformed Member Since: 09 Oct 2010 Location: South Posts: 471 ![]() ![]() |
I used a 25db one on mine and for me it works fine. i get the occasional glitch but no more then I did with the analogue TV. I tried the 128db one but the signal got worse so I went back to the 25db.
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6431 ![]() ![]() |
Am about to test one of these out:
Thanks joe
Rob2529 Member Since: 22 Nov 2010 Location: Wirral, uk Posts: 1470 ![]() ![]() ![]() |
I'm watching this with anticipation. I got one of these http://www.eonon.com/Others/Others/V0012.html to try and get away from having to watch the same dvd with my son every journey. When the cars stationary the signal is pretty good but on the move it's fair to say |
Mine is not to bad on the move. It does get the occasional glitch but definately no more than the old analogue TV did. I only use a single amplified 25db on the same side as the entertainment compartment in the rear.
A bit nippy outside this evening, but just tested out the aerial:
Sounds good. Does anyone know if the ones I got with my system have a Db gain or if there just bog standard aeirels? [img]http://www.fuelly.com/driver/rob2529/range-rover[img/]
Looking at the pictures they are not the standard crappy aerials, yours are amplified 80db.
The box is great I think I might be expecting to much from it though. Will just download a few films onto a pen drive and use that when the signal drops. Out of interest what is the Db thingy and if I got a 120Db aerial would it be better? [img]http://www.fuelly.com/driver/rob2529/range-rover[img/]
I thought that a stronger aerial would be better which is why I tried the 128db type but after having a play I found that wasnt the case. Thats why I ended up going back to the 25db one. The 128db one was even crappy when I was stationary.
