Home > Maintenance & Mods (L322) > Have I been unfortunate or do FFRR frequently throw faults?
claud
United Kingdom 2018 Range Rover Autobiography TDV6 Corris Grey
I have had the call from the dealer, my Evoque is coming in around Christmas and sadly I will be part exchanging the Vogue SE. It has been the best car I have ever had! but not reliable or fuel efficient, that is part of the reason it is going, plus I fear residuals will plummet when the new model FFRR hits the press next year.
Experienced Land Rover owners tend to be forgiving over a few niggles as the cars themselves have so many redeeming characteristics.
However the FFRR can't go for three months without some fault or other involving major warranty work:
3 fuel injectors,
replaced Webasto heater
Relaced Alternator
New active lighting ECU
uneven idle
wobbly fuel guage
remote heater software failure
TPMS fault
glove box not opening
battery drain and failing to start
That is the main reason why I am not getting another Vogue.
I am on fist name terms with the Guava team, they have been stellar in supporting me through Disco 3 and FFRR issues, they have seen the Freeloader once .........for a service.................oh and the Defender, despite being 21 years old, has never had a fault.
Will the Evoque be just as Reliable, only time will tell.
The good news is I have a lot of FFRR accessories to sell in the new year and they will all be posted on this forum! 2018 Range Rover Autobiography
2010 Land Rover Freelander XS
1959 Series II
1950, 1952, 1954. 1955, 1957 Series I
1952 Minerva Ambulance
Post #96953 10th Dec 2011 8:39am
A1GSS
Re: Have I been unfortunate or do FFRR frequently throw faul
Hi
What was the cause of these two? Graham
____
Gone: 10MY L320 RR Sport HSE, Ipanema Sand
Gone: 20MY Jaguar iPace HSE, Silicon Silver
Gone: 17MY RR Evoque SE Tech, Loire Blue
Gone: 08MY Discovery 3 XS, Stornoway Grey
Gone: 07MY FFRR TDV8 Vogue, Stornoway Grey
Post #96971 10th Dec 2011 12:18pm
TugRR
Hi Claud -
It's funny, as I was thinking of starting a RELIABLE FF thread . . . . .
I've had my car over a year - it's a facelift 06MY Vogue - bought with highish miles and FSH. I've had very few problems with it, just the same as everybody else - flat batt etc. Other than that, it's been faultless, with no warning lights and everything works !
It took us to Italy this summer on hols - no probs.
These can be pretty scarey (not SCAREY !) cars to own, particularly a few years down the line and I read other people's posts sometimes with a pinch of salt . . . . .
You never get to hear about the good ones Whistle
Thumbs Up Where do you go after one of these . . . ?
Post #96985 10th Dec 2011 2:42pm
scary =
scarey =
i to have had little problems with mine except the usual maintenance stuff.. ... - .- -.
Post #96989 10th Dec 2011 3:08pm
bozmandb9
2013 Range Rover Vogue SE TDV8 Causeway Grey
You can have a run of bad luck, or a car which seems to suffer problems all the time. I've been lucky with mine apart from minor suspension knocks, and EML coming on sometimes for no good reason, it seems to be great.
My last one didn't have any problems either, but my first one with the bulletproof BMW 4.4 engine needed a new engine new to camshaft wear! Mad 2012 SDV8 Vogue SE
Post #96990 10th Dec 2011 3:32pm
claud
Graham
Regarding the remote heater software failure, my Webasto heater stopped working. It was replaced under warranty, but it could not be started by the remote or on the timer to heat the cabin. It turned out there was a software glitch that took Land Rover a few days to sort out, The HVAC is a BMW system, unfortunately Land Rover ceased the technical support agreement with BMW when TATA took the over. As a consequence it it takes them quite a while to sort out BMW code issues.
I think the glove box is misaligned and the electric catch does not slide across when the button is pressed which is solved by an old fashioned thump! 2018 Range Rover Autobiography
1959 Series II
Post #97040 10th Dec 2011 8:44pm
A1GSS
Ahah, thanks
I'll pass the info about the software on to Lookers.... Graham
____
Post #97042 10th Dec 2011 8:48pm
