Home > Technical (L322) > Battery jump points
DBMONKEY
England 2007 Range Rover Vogue SE TDV8 Java Black
Battery jump points
Hi
Have had my ffrr for a couple of months, but only got round to using the fbh for the first time this morning (well set the timer to run this morning at least). Well, got in the car 10 mins after it had finished doing its thing, and dash was flashing more than my Xmas tree...and wouldn't start up. Got the AA guy out who checked the battery condition and said it was fine, but I should not be using fbh as OEM batteries aren't up to the job - pretty annoying having spent sooooo much to buy the bloody car. Any who, will look to replace it soon for the Bosch hopefully but in the meantime I wanna know why my car has no positive jump point in front of the bulkhead - the aa bloke just connected to the battery point itself. Looking in the manual, that is supposedly dangerous cos of the pyro device.... Did they change the wiring at some point? I have an 07 plate...
Thx
Post #97064 10th Dec 2011 11:17pm
thats a bit pish as OEM batteries should be upto the job, mines on the original battery and still doing well touch wood Very Happy
What battery is fitted to yours, AH and CCA power?
Post #97066 10th Dec 2011 11:24pm
DBMONKEY
It's land rover / varta. 90 ah. And 950 amps
Post #97067 10th Dec 2011 11:37pm
it should have a CCA rating of 110 as the diesels need this Smile
Post #97068 10th Dec 2011 11:41pm
DBMONKEY
Thx kingpleb, need to upgrade to the Bosch one at some point soon. However, am still confused about the lack of positive jump point in front of the bulkhead... Any ideas?
Post #97069 10th Dec 2011 11:48pm
PaulB
2017 Range Rover Autobiography SDV8 Loire Blue
My Varta died today, that was a 95
Bosch 110 fitted Thumbs Up
Sorry cant help with the jump point as I have a 05 diesel.
Post #97072 11th Dec 2011 12:02am
It should be just infront of the battery on that scuttle panel and be covered with a flap with a 1" '+' sign on it Smile
Post #97073 11th Dec 2011 12:03am
DBMONKEY
Defo not there, but there is a large red cable going thru that point that then disappears towards the front of the engine bay. Will take a pic and work out how to post on here in the morning. Cheers guys
Post #97074 11th Dec 2011 12:08am
Jpickie
United Kingdom 2007 Range Rover Vogue SE Supercharged Stornoway Grey
I also have an 07 with the large positive cable running through the bulkhead and don't have a jump terminal or any pyro device as shown in the handbook, sounds like you are not alone! MY2007 S/C - Stornoway / Jet
Post #97078 11th Dec 2011 1:03am
Nomad
United Kingdom 2012 Range Rover Autobiography 5.0 SC V8 Zermatt Silver
My 2007 TDV8 does not have the forward 'jump' post nor the pyro device. Looks like they decided to do without for us. I think I'm happier without the pyro device to worry about. 2012 5.0L S/C
Previous:
3.6 TDV8
4.4 HSE
P38 4.6 HSE
Classic 3.9
90 County
Series3 Lightweight
Post #97089 11th Dec 2011 9:50am
sleepezy
My 07 TDV8 does have the forward jump post (I know for sure as I had to use it yesterday Sad gotta love the cold weather), not sure about the pyro and it's too cold for me to go have a look!
Post #97091 11th Dec 2011 9:56am
dan_uk_1984
The pyro device was removed with the new ford system as I believe most of the SRS was changed with the new ford electronics - they don't have a pyro battery disconnect system.
Unsure why some people have a positive jump point and not others though.
Post #97096 11th Dec 2011 12:11pm
awclymm
I have a 57 plate TDV8 Vogue SE and mine doesn't have the jump point in front of the bulkhead - not sure about the pyro, because I don't know what it looks like....!
Post #157379 14th Dec 2012 1:02pm
sleepezy
07 TDV8 with no pyro but do have th jump post
get the alternator checked out - may be that at fault (it was on mine and chap said in general people blame the battery but the fault tends to lie with the alternator, new gel batteries excluded...)
Post #157384 14th Dec 2012 1:31pm
GraemeC
United Kingdom 2007 Range Rover Vogue SE TDV8 Zermatt Silver
07 TDV8 with no pyro and no jump point!
Had to jump start it this week as battery was flat after running the FBH for 30mins (it was -3)
I'd been running the FBH every morning and evening for about a month, with a 12m each way commute so it may have been a cumulative effect on a 5 year old batter.... I've had the heated seats and steering wheel on as well!
On holiday next week so going to fit a bigger 110ah battery - gotta love that FBH in the morning! 2007 Zermatt Silver TDV8 Vogue SE - now sold but was a great car!
Post #157399 14th Dec 2012 2:14pm
