![]() | Home > My Range Rover > Goosed Battery |
RRUK Site Supporter Member Since: 08 Jun 2007 Location: UK Posts: 6374 ![]() ![]() ![]() |
The TDV8 has been sounding a bit sluggish when starting recently, tonight its just stopped working altogether!
simon1233 Member Since: 13 Jun 2011 Location: Leyland, sometimes Darmstadt Posts: 650 ![]() ![]() |
I got that type of noise immediately before my alternator failed. I think it must be due to low voltage??
Interesting comment re the alternator, that might all add up too as too why I am having battery issues.
Kegs down , assume the position …….. |
Not sure if it was the alternator that was making the noise, but noticed the sounds you mentioned as I drove it back from the post office, 15 minutes later the alarm went off on the driveway and I had about 4 volts showing on the battery. Possibly it is other systems making the noise?
Well, the Machine Mart Jump Start 4000 didn't work. |
weak battery + 8 glow plugs + god knows how many ECU's = no chance of starting up
AA man linked up his jump leads and a booster pack, we got it going, but it died again. once it was running again he linked his machine and it was showing a fluctuating charge rate below 14 amps. It almost resulted in a recovery truck coming out.
I believe that replacing the alternator on a TDV8 is a pain in the a |
Easy come easy go.
Just had the dreaded call from the Dealer but its not so bad. |
NKSC Member Since: 09 Nov 2011 Location: Lincs Posts: 156 ![]() ![]() ![]() |
Starting is always a bonus too... |
True enough Nick. Discovery 4 HSE
Good news on the alternator |
