Home > Technical (L322) > FBH Fault....
Page 1 of 3 123>
A1GSS
FBH Fault....
Big Cry
Lookers just came and collected my FF. They're looking into the problem with the cabin heater / FBH. I've agreed they can keep the car at least 2 or three days (they want some cold mornings apparently).
This is the first real test of the Warranty Direct Platinum warranty ... any bets on whether the WD people will cover it?
I'll report back once its fixed.
In the meantime, I'm driving my Audi again. Graham
____
Gone: 10MY L320 RR Sport HSE, Ipanema Sand
Gone: 20MY Jaguar iPace HSE, Silicon Silver
Gone: 17MY RR Evoque SE Tech, Loire Blue
Gone: 08MY Discovery 3 XS, Stornoway Grey
Gone: 07MY FFRR TDV8 Vogue, Stornoway Grey
Post #97410 13th Dec 2011 9:35am
SteveMFr
Site Sponsor
It silly too, as they treat the FBH as a sealed unit - if it don't work, it's replaced. Yet they are relatively simple little bits.
When I was going to law school in Munich I earned my keep as an automotive electrician (strange combination, I know). The shop I worked at installed and repaired these things. I even took part in a 3 day long training seminar at Webasto (just outside of Munich) who make these FBH for most of the OEMs. Not difficult units to understand or repair (motor or transmission is much more complex). Not much more than some electronics, a fuel pump, glow plug and a housing for the flames (and water pump/hoses).
And these days everything is diagnosed via electronics - we still did it by hand.
As I said: silly.
RRC 2Dr, RRC 4Dr,
P38, and 2 L322s
Post #97466 13th Dec 2011 12:53pm
LR technicians are not trained for repairing anything these days.
1. Diagnose faulty part
2. read LR workshop manual on how to do the job
3. Replace faulty part
4. Pray you did it right.
There's little skill anymore, my grandfather would turn in his grave. Discovery 4 HSE
1993 90 Tdi
Post #97468 13th Dec 2011 12:56pm
Rambles
2011 Range Rover Vogue SE TDV8 Stornoway Grey
did they explain why they wanted cold mornings?
if they give you story that the warm temperatures are causing the FBH to not operate properly, then they are spinning you a story. The ambient temperature does not effect the duration of the FBH cycle.
Post #97552 13th Dec 2011 7:55pm
A1GSS
Big Cry
It's bust. £1300 to replace it of which £1100 is the part. Warranty Direct don't want to know.
Anyone a contact for a Webasto repairer? Graham
____
Post #97889 15th Dec 2011 8:58pm
PaulB
2017 Range Rover Autobiography SDV8 Loire Blue
What reason has WD given?
Post #97891 15th Dec 2011 9:03pm
If you do a quick search on google there is a VERY good guide on how to tear it down and repair it.
What part of it is faulty? odd's on the glowplug or the electronic module Sad
Post #97894 15th Dec 2011 9:12pm
A1GSS
PaulB, it's "not in the list of covered items". Which it isn't... wonder what else isn't covered?
kingpleb, yes, but I'm no mechanic, I don't mind paying someone to fix it but I simply don;t have £1300. Graham
____
Post #97895 15th Dec 2011 9:20pm
simon1233
Ouch, that's an expensive part!
Must be able to get one from a breakers for a couple of hundred, surely Thumbs Up
Post #97897 15th Dec 2011 9:31pm
mzplcg
Mine's bust as well Sad Well technically it isn't, it has a wiring fault which is preventing it working but warranty is covering it. Loom on order. Thumbs Up
Anyhow, the thing is a simple enough matter to get out and fix. It's a bloody fire for chrissakes, albeit enclosed in a container. I've fixed dozens like it in the form of truck night heaters. There's even a few on EBAY who will recondition them for you, usually the cost of parts (sod all) and a couple of hours labour.
Go on, get the spanners out, you know it makes sense Rodders. Seriously, £1300 ?? Rolling with laughter Rolling with laughter Bring the thing to me. I'll do you a £300 quid discount, call it a flat grand. Rolling with laughter Rolling with laughter Be the easiest grand I ever made.
Post #97900 15th Dec 2011 9:53pm
http://www.techwebasto.com/
http://www.fullfatrr.com/gallery/index.php?cat=11242
Post #97901 15th Dec 2011 10:00pm
Whats the actual fault with it though fella?
If its going to get chucked afterwards i wouldn't mind having it so i could service it and learn a bit from it if that would be ok with you??
Post #97902 15th Dec 2011 10:02pm
A1GSS
Can it be removed without draining coolant and stuff? And run teh car happily with it missing? Might be something in this. Graham
____
Post #97903 15th Dec 2011 10:06pm
mzplcg
Yes. Clamp pipes while removing. Fit a bridging piece of copper pipe temporarily. Thumbs Up
Post #97904 15th Dec 2011 10:08pm
You would lose some coolant but you could get a standard joiner pipe and just loop that section of the colling circuit to bypass it.
This is a method often used on cars where heater matrix's are leaking and are a real biatch to replace. Commonly happens on older Xantias that are run into the ground as its quoted at 12hours to replace the unit... Took me 2 days on my own to do mine Sad
Post #97905 15th Dec 2011 10:08pm
Page 1 of 3 123>
