Home > Off Topic > SKY HD box problems
SKY HD box problems
Just wondered if anyone else has had the problems we are getting with our SKY + HD box and can shed any light on it.
When you select to go to the EPG, the box reacts as if you have pressed a button twice, so you see the EPG and then BANG! Straight into BBC1.
It seems to do this with all sorts of commands, like paging through the EPG it will do 2 pages in quick succession when you press the button on the remote once. If you go to play a recording it skips past the info screen and just starts playing.
We now have another new problem. Recordings are failing, and what seems to occur is that the channel you want to record shows as "No satellite signal is being received" however if you go up one channel then back down, the signal is fine and the programme is playing as normal.
It's driving me potty! Censored
I know that if I ring SKY they will want to send someone out with a callout fee and then say I need a new box at £250.
Any ideas from the collective? Discovery 4 HSE
Post #97654 14th Dec 2011 11:40am
Have you tried powering the box off for a while? Also have you tried clearing it of dust with a hoover as they can overheat?
What type of box is it? Thomson or samsung?
I believe the most common issue is a power board failure and that these can be bought if you want to replace it yourself.
Personally i just take out a new 12month contract every year to get a new box and install to get it all checked over Smile
Post #97656 14th Dec 2011 11:46am
i would suggest a planner rebuild and new battery's [ Mr. Green ] in the remote..
planner rebuild http://www.sky.com/helpcentre/tv/sky-plus/...r-rebuild/ ... - .- -.
Post #97657 14th Dec 2011 11:47am
Googsy
Not sure have you tried reset by unplugging box ( sure you have but just checking)
I have a SKY HD box here if your stuck was about 6 months old when I switched to another provider Thumbs Up
Cheers
Googsy Present :2008 TDV8 HSE
Gone Audi A5 2.7TDI
Gone Discovery 3 HSE
Gone Mercedes CLK
Gone Range Rover 2.5 DSE
Post #97660 14th Dec 2011 11:48am
The power off thing is a regular occurence as it freezes up so often and the remote won't work.
Was just reading on the SKY Support site about the planner rebuild so may try that, trouble is it will wipe stuff off and the Wife will go MENTAL when Biggest Loser is not there...
there's no dust on it, it's very well ventilated and the remote batteries are new. We have two remotes and it happens with both, so it's an issue with the box. Discovery 4 HSE
Post #97664 14th Dec 2011 12:01pm
planner rebuild will not delete recordings adam...
quote ''Recordings in your planner will not be deleted'' ... - .- -.
Post #97666 14th Dec 2011 12:12pm
Just tried the planner ebuild and it wont get to that menu! Censored
I get a message saying "menu not available while 2 recordings are in progress", but there are NO BLOODY RECORDINGS in progress.
Heap of Censored . Discovery 4 HSE
Post #97667 14th Dec 2011 12:16pm
Power it off then as that could be the cause and its taking up processor time and slowing your box down and thus causing issues.
The top of the box may not look dusty but i bet the fan has been pulling dust inside it, hoovering right onto the vents should help relieve some of it as it acts as a blanket and kills electrical components Sad
Post #97668 14th Dec 2011 12:21pm
supershuttle
Probably the bonnet catch Very Happy Geoff
Post #97702 14th Dec 2011 5:19pm
Laughing ... - .- -.
Post #97703 14th Dec 2011 5:20pm
Have you tried a Virgin Box Whistle
Post #97704 14th Dec 2011 5:32pm
Just buy a sky HD box off gumtree or ebay for £30/40
Post #97712 14th Dec 2011 6:24pm
Googsy
£20 + postage from Uncle Googsy! Present :2008 TDV8 HSE
Gone Audi A5 2.7TDI
Gone Mercedes CLK
Post #97762 14th Dec 2011 9:58pm
tboner001
England 2014 Range Rover Autobiography SDV8 Fuji White
Just ring sky get a brand new HD box for £90 fitted by them and if you want to clone the planner thats easy to do takes 10 mins to open the box clone the drive and put it back in another 10 mins Far to many gone...
Post #97766 14th Dec 2011 10:24pm
