![]() | Home > Technical (L322) > fuel burning heater |
The doc Member Since: 25 Mar 2007 Location: In car hell :-( Posts: 425 ![]() ![]() |
Set the timer on the sat nav - you will soon know - I've never seen one without btw |
Andy Member Since: 24 Feb 2009 Location: Shropshire Posts: 2947 ![]() ![]() ![]() |
I have it in my sat nav but it blows cold air. 2010 MY Vogue SE TDV8 3.6 Stornoway Grey- fully loaded |
hi, yes i have it in my menu but as noddy said, mine too blows cold air, i did only have it on for about a min , may be this was not long enough..is there a sticky for testing its operation
itguy Member Since: 08 Dec 2009 Location: Melton Mowbray, UK Posts: 113 ![]() ![]() |
A good test will be to switch it on manually (or via the timer) and stand outside the car. If you can hear a clicking then it should be working as this noise is the fuel pump pulsing fuel into it. Do this with the engine not running. FFRR TD6 06MY. Cairns Blue, Blue Hide. LR 7 Spoke 20" Wheels, S/C Grill and Vents. Privacy Glass and Side Steps |
ENVOY Member Since: 25 Mar 2007 Location: up a track in the middle of nowhere Posts: 239 ![]() ![]() ![]() |
how do you turn it on manually ![]() |
hi, i was told that only diesels have them and not petrols...true or false.. and if you have it how long does it take to warm up. V8 facelift Range Rover Autobiography 22" wheels.
that sounds about right about only diesels having them fitted, i have read that somewhere before im sure of it! they take about a minute to run through the start up procedure but it will take about ten to fifteen minutes to warm the water up in the engine (if the engine isnt running)
The FBH was fitted to all TD6s as standard but control of it via the computer and remote fob was optional and then added later in the MYs.
You can buy timers or remote sytems on ebay that will bring it to life. Timers are around £65 and the full webasto remote system is around £175 ish
hi, if i get the option up on my nav screen,as i do would that indicate i have it.. V8 facelift Range Rover Autobiography 22" wheels.
I had a good look but all I could see was engine - I'll look again in the morning.
adara Member Since: 09 Dec 2008 Location: Eastern Europe Posts: 875 ![]() ![]() ![]() |
The FBH is under the battery tray - so it's invisible without dismantling stuff... |
Shows what I know |
You should be able to see the exhaust of the FBH by looking down the right-hand side of the engine towards the floor. It's a metal pipe about 1" in diameter that just pokes out of the right-hand side.
