Home > Technical (L322) > What is the dot above odometer?
EDWARD757
2007 Range Rover Vogue SE TDV8 Java Black
Hi,
I have noticed a small black dot appear above the odometer on the left hand dashboard display. Any ideas what this means - it looks as though it is supposed to be there and telling me something. Had a quick look in the manual but could not find anything.
Kind regards,
Ed '96 Volkswagen Polo 1.4CL - SOLD
'00 Audi A3 1.8T - SOLD
'97 Lotus Esprit V8 - SOLD
'03 BMW M3 - SOLD
'93 Range Rover 3.9 Vogue SE - SOLD
'92 Peugeot 205 GRD - DIED
'99 BMW 540i Touring - SOLD
'94 Peugeot 405 GDRT - SOLD
'00 Peugeot 406 HDI estate - 63mpg! - SOLD
'08 Range Rover TDV8 Vogue SE - SOLD
'11 Skoda Fabia Greenline II - 94.2mpg!- SOLD
'07 E61 BMW 530d msport touring - SOLD
‘20 Tesla Model 3 SR+
‘20 Tesla Model 3 Performance
Post #97763 14th Dec 2011 10:04pm
Reformed
I thought that meant its been tampered with at some point, if its warning you a small triangle appears both sides of the display Reformed
Post #97764 14th Dec 2011 10:07pm
EDWARD757
as in the mileage altered?
We do not leave her with anyone other than the LR dealer. '96 Volkswagen Polo 1.4CL - SOLD
'03 BMW M3 - SOLD
Post #97765 14th Dec 2011 10:14pm
Im sure it means something has changed. The mileage is stored on several ECU's. Off the top of my head the dash binical ECU and the BCM ECU, if either has been changed with and older or newer one the dot appears to show a miss match. The ecu's will show the higher mileage. [img]http://www.fuelly.com/driver/rob2529/range-rover[img/]
Post #97768 14th Dec 2011 10:32pm
AMD
Have you got a pic?
You haven't sneezed have you? Current MY2020
Gone: 1 x L405 and 2 x L322's
Post #97769 14th Dec 2011 10:34pm
EDWARD757
Very good! I wondered whether it was a mark but it is on the display.
They have recently been trying to fix a blinking (literally) main beam and after changing the indicator stalk, plumped for a Headlight control module (the wizardry that sits behinf the headlight controls) change. This seems to have cured it - they were as surpirised as me!
I will query this when I next speak to them as the car has currently lost the 'quick swipe of the indicator for 3 flashes' facility. Not the end of the world but I will have that done next time she is in with them. '96 Volkswagen Polo 1.4CL - SOLD
'03 BMW M3 - SOLD
Post #97770 14th Dec 2011 10:40pm
daveo
the mileage is held in the clocks,LCM and main ecu, if any of these are change you will get the dot appear, if a new unit is fitted then it will be coded to your car and the correct mileage inserted.this can only be done once. V8 facelift Range Rover Autobiography 22" wheels.
Post #97772 14th Dec 2011 10:51pm
As Daveo said. Sounds like they have used a spare/pre used LCM which obviously has a different mileage stored and the miss match is causing the dot. If they change it back will the Dot go? That's the million dollar question I would be asking. [img]http://www.fuelly.com/driver/rob2529/range-rover[img/]
Post #97777 14th Dec 2011 11:26pm
daveo
if they put your unit back it should be fine but i would want to know why they have gave your car back with a used and unregistered unit on your car..what did your car go in for Exclamation V8 facelift Range Rover Autobiography 22" wheels.
Post #97782 14th Dec 2011 11:43pm
