![]() | Home > Technical (L322) > FBH Fault.... |
A1GSS Member Since: 24 Dec 2010 Location: Saffron Walden, Essex Posts: 1973 ![]() ![]() |
The FFRR FBH or the Xantia Matrix...? Graham ____ Gone: 10MY L320 RR Sport HSE, Ipanema Sand Gone: 20MY Jaguar iPace HSE, Silicon Silver Gone: 17MY RR Evoque SE Tech, Loire Blue Gone: 08MY Discovery 3 XS, Stornoway Grey Gone: 07MY FFRR TDV8 Vogue, Stornoway Grey |
the xantia heater matrix |
Phew. Graham
I'll check RAVE over the next few days and see what it quotes but can't imagine its a big job, probably 2 spanners on the haynes scale |
2 days later.... ![]() ____ Gone: 10MY L320 RR Sport HSE, Ipanema Sand Gone: 20MY Jaguar iPace HSE, Silicon Silver Gone: 17MY RR Evoque SE Tech, Loire Blue Gone: 08MY Discovery 3 XS, Stornoway Grey Gone: 07MY FFRR TDV8 Vogue, Stornoway Grey |
There is nothing in the RAVE on repairing the FBH. I just posted most of the relevant info in the 'Have I got an FBH' thread in general.
Thanks Steve, really helpful. I'll take a look. Graham
Right. Bit of good news...
Renegade2 Member Since: 03 Dec 2011 Location: Cardiff Posts: 134 ![]() ![]() ![]() |
Hi Boffhead, is it a big job removing the unit?Mine needs looking at and ceratainly not going to main dealers. Mine does not seem to be firing at all. I am going to do the disconnect the battery for 10secs to see if this does a reset but failing that it will need to come out. |
Removal looks reasonably straightforward (instructions posted on another thread somewhere), but once it's out you've got coolant pipes and a fuel pipe to worry about if you want to use the car.
Car back from Lookers last night. At the eye watering cost of almost £1400 I have a new FBH and a toasty warm car this morning. Yay! All good. All I have to achieve now is receive the repayment from Warranty Direct. They covered this fault because it was proven by Webasto Tech Services and LR's technical bods that the "failure to fire" problem was down to signalling faults caused by a faulty FBH ECU, which happens to be built into the FBH itself. The ECUs are covered by the WD warranty, so to replace the ECU I had to have a new FBH. ![]() ____ Gone: 10MY L320 RR Sport HSE, Ipanema Sand Gone: 20MY Jaguar iPace HSE, Silicon Silver Gone: 17MY RR Evoque SE Tech, Loire Blue Gone: 08MY Discovery 3 XS, Stornoway Grey Gone: 07MY FFRR TDV8 Vogue, Stornoway Grey Last edited by A1GSS on 6th Jan 2012 3:33pm. Edited 1 time in total |
simon1233 Member Since: 13 Jun 2011 Location: Leyland, sometimes Darmstadt Posts: 650 ![]() ![]() |
Excellent news Graham |
SteveMfr you do seem to have an excellant knowldge of the FBH unit but mine is quite puzzling.
Pitouille Member Since: 18 Jan 2012 Location: Geneva Posts: 1 ![]() ![]() |
Hello,
