Home > Technical (L322) > Front Parking Sensor Sensitivity
Zeus
Scotland 2004 Range Rover Vogue 4.4 V8 Java Black
Hi all, New to the forum... first post.
Had a quick search but not found the answer....
My rear parking sensors are great - work just as you would want.
The fronts work but are too active - they seem to beep at the slightwat thing that is a long way off. Is there any adjustment to the sensitivity to calm the fronts down a little to the same as the rears or is this just the way it always is?
Thanks
Zeus 2004 4.4 V8 Vogue
Post #98215 18th Dec 2011 10:39am
Stephen.125
2017 Range Rover SVAutobiography 5.0 SC V8 Indus Silver
Welcome along!
I found that the fronts are pretty well calibrated to allow you to pull out of a space you parallel parked in. I guess if they seem too sensitive it could be a fault on a particular sensor?
Is it worse on one side? For the outer sensors you can stand next to the wing and lean around the front with your hand.
I'm not sure how to calibrate the sensors but I guess with the right diagnostic stuff anything should be possible?
Post #98218 18th Dec 2011 11:47am
