Home > Maintenance & Mods (L322) > New Brakes time
Kads
New Brakes time
Where is the best place to get pads and discs from, needs all four corners replacing? Kads
Post #98289 19th Dec 2011 11:58am
Simes
United Kingdom 2011 Range Rover Autobiography Black TDV8 Barolo Black
Have a rummage around eBay - I got mine from there - Britpart Drilled and Slotted discs all round and Heavy Duty EBC pads for about £150.
Post #98290 19th Dec 2011 12:01pm
ukrangie
If you are looking for a dealer to do it, the cheapest place I found was Lookers at Bishop Stortford. At £750, it wasn't cheap.
If you can do it yourself, you can probably save yourself a little money buying the parts from Duckworths
http://www.duckworthparts.co.uk/landrover/...Discs.html Paul
Twitter - Facebook
Post #98301 19th Dec 2011 2:00pm
I wouldn't reccomend drilled discs as grooved would be more than enough for an ffrr.
Drilled eventually crack and turn discs to scrap after some medium to heavy use Sad a few different sets I've tried on different cars all do the same on the end Sad
Post #98304 19th Dec 2011 2:32pm
Kads
I need just parts, as I can fit them on myself, any recommended supplers or pads and discs, I have seen a set of Brembo calipers and pads on e-bay is it worth the upgrade? Kads
Post #98306 19th Dec 2011 2:39pm
Reformed
When I did mine I got them from island 4x4, can't remember total price but it wasn't that much.
Can't help with the upgrade, I only changed all 4 discs and pads. Reformed
Post #98307 19th Dec 2011 2:52pm
Standard pads and discs should be fine or less you tow lots and lots.
Then I'd reccomend 3G grooved Discs and pagid grey stuff pads for up front an standard at the rear if towing a lot as my experience of that combo on a previous car showed they are well worth the money Smile
Post #98310 19th Dec 2011 3:09pm
done mine, front and back ,pads and discs for £140 all in from ebay.. ... - .- -.
Post #98319 19th Dec 2011 4:01pm
EDWARD757
2007 Range Rover Vogue SE TDV8 Java Black
Nick and yeovil Landrover - genuine parts that do as designed... '96 Volkswagen Polo 1.4CL - SOLD
'00 Audi A3 1.8T - SOLD
'97 Lotus Esprit V8 - SOLD
'03 BMW M3 - SOLD
'93 Range Rover 3.9 Vogue SE - SOLD
'92 Peugeot 205 GRD - DIED
'99 BMW 540i Touring - SOLD
'94 Peugeot 405 GDRT - SOLD
'00 Peugeot 406 HDI estate - 63mpg! - SOLD
'08 Range Rover TDV8 Vogue SE - SOLD
'11 Skoda Fabia Greenline II - 94.2mpg!- SOLD
'07 E61 BMW 530d msport touring - SOLD
‘20 Tesla Model 3 SR+
‘20 Tesla Model 3 Performance
Post #98321 19th Dec 2011 4:29pm
dan_uk_1984
Never had a problem with pattern part brakes from Island4x4. I've always used pattern parts for brakes on every car I've ever owned. Steel disc is steel disc... The pads tend to be a little softer which means the pads wear out rather than wearing the disc out.
When you buy genuine parts you aren't necessarily getting the same "dependable quality" each time. Merely the cheapest deal LR happened to come across. At least if you buy mintec you know you're getting mintec vs whatever crap LR have put in the box.
Same goes for LR oil filters - absolute junk I have two in the garage, same part number but different manufacturers. I tend to stick with MANN or K&N for oil filters.
Post #98341 19th Dec 2011 8:26pm
