Home > General > key programming help
dannyp15
United Kingdom 2004 Range Rover Autobiography 4.4 V8 Alaska White
need help i pulled the fuse 46 Big Cry and now my car want start everything lights up but want crank also it doesnt make the noise when you put the key in the ignition
Post #98563 20th Dec 2011 9:16pm
put the fuse back in? ... - .- -.
Post #98565 20th Dec 2011 9:18pm
dannyp15
ive done that Rolling with laughter
Post #98568 20th Dec 2011 9:27pm
Reformed
What made you pull the fuse? Reformed
Post #98570 20th Dec 2011 9:29pm
dannyp15
someone said it would reset the cd system Censored Censored Censored Censored
Post #98572 20th Dec 2011 9:37pm
dannyp15
tried to do the re programming thing now it want even turn in the barrel what a c Censored
Post #98573 20th Dec 2011 9:38pm
mrd1990
United Kingdom 2002 Range Rover HSE Td6 Oslo Blue
Is it in p ?
Few things to try;
Take the key out > lock car manually > unlock manually > try again
Take key out, try turning the wheel so it 100% locks, put key back in
Disconnect battery for 15min
Hammer
Check fuse
Does the CD system need a pin number?
Post #98582 20th Dec 2011 10:22pm
daveo
put the fuse back in, disconnect the battery for a while reconnect should be all good.. V8 facelift Range Rover Autobiography 22" wheels.
Post #98592 20th Dec 2011 11:43pm
dannyp15
thanks for your help on this...
had a guy come round yesterday to look at it and it turns out it was the battery terminals that where corroded he cleaned them up and everything back to normal Bow down
he programmed the key and good as new
he also does all the facelift stuff as well lights everything
he is going to do my rear 2010 leds black verison £450 fitted
Post #98884 22nd Dec 2011 3:35pm
daveo
sounds like mark... Question V8 facelift Range Rover Autobiography 22" wheels.
Post #98902 22nd Dec 2011 4:37pm
dannyp15
spot on it was mark
nice guy
Post #98933 22nd Dec 2011 6:36pm
