![]() | Home > Technical (L322) > Airbag warning light |
Did you disconnect the battery whilst removing the steering wheel? |
the_engineer Member Since: 25 Aug 2011 Location: alexandria Posts: 42 ![]() ![]() ![]() |
as per instruction yes I did disconnect the battery. A wise decision I thought as the airbag and wheel electrics were being disconnected |
Could be that the rotary coupler has been damaged when you removed the wheel |
don't think I damaged anything. Was pretty careful and all the connections went back together as they should |
fisha Member Since: 25 Sep 2009 Location: Scotland Posts: 1514 ![]() ![]() |
I disconnected the battery and removed a door airbag after waiting a long time before touching it ... the light is now on and I cant reset it via my faultmate diagnostic tool. grrr. V8 or else ... |
Richcl Member Since: 23 Sep 2010 Location: Tewkesbury, Glos Posts: 1011 ![]() ![]() ![]() |
It's a garage job, as it's safety related. Any decent garage will be able to reset, unless of course a problem actually exists.
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16395 ![]() ![]() ![]() |
Ive taken 100 steering wheels off without the light coming on afterwards, so i would say you definately have a fault now. Maybe not plugged in correctly.
