Home > Technical (L322) > Anyway to keep steering lock disabled without battery?
rads
2005 Range Rover Vogue SE Supercharged Tonga Green
As per title really.
Going to be fiddling with front suspension (again Sad ) and would like to have the steering lock off, but also need to disconnect the battery.
Any way that can be achieved?
David
Post #98532 20th Dec 2011 6:23pm
leave the key in the ignition? ... - .- -.
Post #98536 20th Dec 2011 6:50pm
rads
Possible, I guess.
I find it hard to believe there is a mechanical linkage between the key (on the centre console) and the steering column. I had assumed an electrical steering lock, something like a solenoid that pulls a pin out of the column when the key is in, which would, of course, not work when the battery is disconnected.
Can only try it!
David
Post #98602 21st Dec 2011 12:37am
M44K TS
To take the battery off, you need to let everything shut down in the car first, I doubt leaving the key in the barrel will allow everything to shut down safely for disconnecting the battery.
In short, no, I very much doubt it. 2006 Mercedes CLS
1991 Retro-style Mini
But really finding it hard to fight the urge for a S/C...
Post #98604 21st Dec 2011 1:07am
