![]() | Home > Technical (L322) > Are these issues to sort or just the way newer cars are? |
| RRUK Site Supporter Member Since: 08 Jun 2007 Location: UK Posts: 6383
The only reason I have noticed these two issues is that its different to my TD6 Vogue.
| JOKER Member Since: 11 Sep 2008 Location: Sconnie Botland Posts: 15876
1/ I have the same problem with the heater i actually started thinking my Thermostat was goosed .....
| ukrangie Member Since: 20 Jun 2009 Location: Kent Posts: 520
My climate takes a minute or two to pump out hot air. Same with cold. Does it have enough gas? In older cars there use to be a piece of glass on top of the compressor where you could see if was running low. I am sure it's not like that anymore.
| VMPP Member Since: 12 Jul 2009 Location: Lisboa Posts: 413
For the HK system the best advice i give you is to use it with everything at 0
Cheers chaps |
| All times are GMT |
