![]() | Home > Maintenance & Mods (L322) > DSC, Transmission, Low range, HDC etc. Inactive, Susp low |
Sounds Battery related so a RESET may be in order. I think you disconnect battery teminals and briefly touch them together but you better check with other answers first. |
Dolphinboy Member Since: 08 Dec 2009 Location: Bristol Posts: 3273 ![]() ![]() ![]() |
check your battery conections (especially neg pole) and/or your ABS module connections. all these lights coming on point to the ABS module not being able to read the inputs from all the different sensors and so brings up a fault for each of them
Hi guys, thanks for the quick feedback. Will do the battery trick like Gaz suggested.
Andy_J Member Since: 14 Nov 2011 Location: Muir of Ord Posts: 479 ![]() ![]() ![]() |
I wouldn't recomend using WD40 to clean electrical connectors as it is oil and can act as an insualtor if not cleaned off properly 56 TDV8 Vogue SE
Hi Andy, totally agree, unfortunately it is the only stuff I have here right now. Not easy finding anything here. I would love to get my hands on some decent contact cleaner !!
