Home > Maintenance & Mods (L322) > What bulbs are in the 2010 FFRR & RRS number plate light
carlos50
United Kingdom 2015 Range Rover Autobiography 5.0 SC V8 Santorini Black
Hi all
As per the what bulbs are fitted in the number plate bulb holder in the 2010 FF & RRS?
I passed a 60 reg RRS and the number plate on the rear was lit up with a crisp white light, not OTT like some LED's give but just the right amount.
Is it a normal bulb witha brighter colour rating or is it LED?
Thanks
Carl
Post #98948 22nd Dec 2011 7:39pm
carlos50
Bump
Post #99096 23rd Dec 2011 2:46pm
type 501... ... - .- -.
Post #99106 23rd Dec 2011 3:20pm
carlos50
But is is a brighter halogen bulb or an LED?
They are brighter than 2002 - 2009, certainly on the 60 plate RRS A/B I passed
Post #99107 23rd Dec 2011 3:28pm
simon1233
If its a crisp white light, then it is likely it will be LED, most likely a 1w SMD type fitting like you get on BMW's etc. There are a lot of lower powered LED bulbs around which don't have a decent power output.
I fitted LED's to my RRS, but have so far resisted the urge with the FFRR. Need to find some good high power output SMD bulbs with the resistors fitted so that the bulb warning light does not come on.
Post #99111 23rd Dec 2011 3:37pm
I fitted these guys to my MY07 and get no errors :-
http://www.ebay.co.uk/itm/140508459316?ssP...1439.l2649 Got - 2017 SDV8 Autobiography in Loire Blue
Post #99112 23rd Dec 2011 3:41pm
simon1233
Alanm_3, are you pleased with the light output? Is it good?
Might have to get some of these if they are up to the job. Have used 0.5w SMD LED's before and to be honest the light was a nice temperature (i.e. crisp and white) but the actual intensity/output left a lot to be desired.
Post #99115 23rd Dec 2011 3:59pm
No complaints at all, as bright, if not brighter than the original bulbs I think, but much whiter! Thumbs Up Got - 2017 SDV8 Autobiography in Loire Blue
Post #99125 23rd Dec 2011 4:38pm
carlos50
Did they fit ok? I was told by an online supplier that I needed a 38mm festoon whereas these are 36mm?
Post #99146 23rd Dec 2011 5:42pm
They were slightly loose when I first tried them, but since the contacts are just steel strips with holes to locate the end of the bulbs, a small bend inwards was all that was neededto tighten them and I've had no issues since. Got - 2017 SDV8 Autobiography in Loire Blue
Post #99149 23rd Dec 2011 6:06pm
carlos50
Do you have a picture of the rear of ur FF at night so I can see how white they are?
I bought some similar LED's for a Mercedes SL a year or so ago and they lit the rear bumper and road aswell as the number plate, very Max Power.
Cheers
Post #99164 23rd Dec 2011 8:32pm
T24RES
I've got the led's and found that if turned directly down were too bright, angled them round and got a nice light instead of a starship Thumbs Up
Post #99216 23rd Dec 2011 11:56pm
crikey ,you got a little fullfat there ian.. Mr. Green ... - .- -.
Post #99238 24th Dec 2011 10:52am
carlos50
alanm_3 and T24RES
Do you have better pictures of your LED's lit up please?.
Post #99586 28th Dec 2011 8:41pm
carlos, for the sake of a few quid why dont you buy some and try them out.. Confused
....and if you dont like them there then stick in your sidelights.. ... - .- -.
Post #99588 28th Dec 2011 8:46pm
