Home > Maintenance & Mods (L322) > Drivers door handle
Andy
Drivers door handle
Tried to open the drivers door the other day and nothing. I now have to get in via the passenger door and reach over to open the door from inside
I'm assuming one of the rods has popped off inside. Is it much of a job to get the door card off? Alternatively, can it be accessed by removing the door handle? I'm told they are removable without having to take off the card.
TIA 2010 MY Vogue SE TDV8 3.6 Stornoway Grey- fully loaded
Post #99050 23rd Dec 2011 10:58am
A1GSS
Pretty straight forward assuming you can get the door open... . Here's a guide :
 Graham
____
Gone: 10MY L320 RR Sport HSE, Ipanema Sand
Gone: 20MY Jaguar iPace HSE, Silicon Silver
Gone: 17MY RR Evoque SE Tech, Loire Blue
Gone: 08MY Discovery 3 XS, Stornoway Grey
Gone: 07MY FFRR TDV8 Vogue, Stornoway Grey
Post #99051 23rd Dec 2011 11:04am
arron
United Kingdom 2005 Range Rover Vogue Td6 Java Black
door cards are easy to get off, just be brave with the clips along the top near the window as they are very tight and remember to take the black plastic clip off the door in the centre and put it back on the door card before putting the card back on. the outer door handle is not removable without taking the door card off.
Post #99215 23rd Dec 2011 11:53pm
carlos50
United Kingdom 2015 Range Rover Autobiography 5.0 SC V8 Santorini Black
Noddy
Did you fix your handle, if so what parts were needed? Mine has just stopped working, described in another thread on here.
Post #103793 26th Jan 2012 11:09pm
carlos50
Ok so I've bought cable FQZ000041 from LR, was only £8 so pleased about that but very surprised that iots 700mm long?
WTF !
So my question is how does that cable connect the external handle to the lock which is about 100mm away?
I don't want to pull the door card to find either I'm going to struggle or I have the wrong item?
I have a feeling the 2 ends clip in to the mechanisms and the rest loops up on itself, hope that's true?
Post #103929 27th Jan 2012 3:16pm
arron
the length sounds about right, when its fitted its looks like a big c shape. fitting it to the door handle is the easy part, the lock mechanism is a bit more tricky. i find it easier to unbolt the mechanism to fit the cable.
Post #104026 28th Jan 2012 12:54am
