![]() | Home > Technical (L322) > Water Loss near middle of RR - Advise please |
RR8701 Member Since: 11 Aug 2011 Location: East Ayrshire Posts: 380 ![]() ![]() ![]() |
Hi Guys,
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35684 ![]() ![]() |
re water droplets, could be the vibration of the engine causing a capillary action from water else where [rainwater] or maybe a/c water.. ... - .- -.
Hi Scarey,
that looks like the air con drain, was the air con on as if it was then thats normal, have you checked your header tank as they are know for getting pin holes in them and leaking. V8 facelift Range Rover Autobiography 22" wheels.
Hi Daveo,
what dave says re pipe...i'd switch the a/c off and check again.
how much water do you lose, i had a pin hole in the header and only found out after wrapping it with paper towel,check your tank cap as well, V8 facelift Range Rover Autobiography 22" wheels.
dave's just reminded me of the problem a member had where he had the wrong pressure rated cap fitted , worth a look.. ... - .- -.
Rob2529 Member Since: 22 Nov 2010 Location: Wirral, uk Posts: 1470 ![]() ![]() ![]() |
That's you aircon dripping. Something to do with removing the moisture from inside the cab. The big issues with leaks in coolant system are: header tank, rad (bottom left looking from the front), hoses. I've had a coolant loss for ages down to my LPG hoses weeping. On the back of the engine is a coolant manifold linking both banks. There's a small hose (2inch) that is a known leaker. You could also have leaks on the valley pan. I had that with mine. I've done a write up on it.
Hi Rob,
CG-SC Member Since: 06 May 2011 Location: Falkirk Posts: 528 ![]() ![]() |
Yip - thats normal, just the aircon evaporator drain.
CG, anyone would think we were copying each others faults |
I was just thinking that LOL......same water issues haha.....
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16342 ![]() ![]() ![]() |
Two points,
