![]() | Home > Maintenance & Mods (L322) > Headliner drooping |
A1GSS Member Since: 24 Dec 2010 Location: Saffron Walden, Essex Posts: 1973 ![]() ![]() |
Here's one option:
Ideally you need to remove it and then reglue it to get it back as it should be with that spray on adhesive.
@antoniasdad : this would make the RSE into a "drive-in cinema" |
geat it retrimmed in leather like an AB model while your at it as it will stop it from happening again if the stitching is used to hold it up |
To be honest, I have been following some of the leather headliner threads |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6424 ![]() ![]() |
Is it really glued up ? I know it may be glued to the trim strips around the edges, but at the tailgate I have a clip fixed to the roof and a clip fixed to the headlining. It's broken so not sure how it works, but I'm going to fix with some velcro strip to hold it up. So this got me thinking that there are more of these clips holding the headlining in place and up around the car. Worth investigating? .
@Joe, I think it is glued on the MY2006 but will have a good look. The way it is coming down indicates that it is glued, it is following the curve on all the edges by the looks of it. Will check though. MY 2010 5.0 SC Galway green and sand interior!!
