Home > Maintenance & Mods (L322) > Squeal sound from rear of car when reversing ???
Ludzy
United Kingdom 2005 Range Rover Vogue SE Supercharged Zambezi Silver
Hi
There seems to be a very loud squealing sound coming from the rear of the car when reversing? Sounds like its coming from the wheel area. At first Assumed it was when I had my foot on the brake but today it started without me touching the brakes. I had the front pads replaced about a month or so ago but I'm certain the noise is coming from the rear. This is getting abit embarrassing now as the noise is very loud. Any ideas what's up
Thanks
Tim Ex FFRR 4.2 Supercharged
www.thecarpetfitter.co.uk
Post #99179 23rd Dec 2011 9:18pm
nbunney
United Kingdom 2018 Range Rover Autobiography SDV8 Corris Grey
Sticking rear caliper?
Post #99180 23rd Dec 2011 9:23pm
Stephen.125
2017 Range Rover SVAutobiography 5.0 SC V8 Indus Silver
Have you run over a pig?
Lol no, could it be a binding handbrake shoe?
Post #99181 23rd Dec 2011 9:23pm
Ludzy
Hmmmmmmm didn't think of that. Sticking rear caliper. As for the hand brake I did think that.
And as for the pig! The wife assures me she hasn't hit anything let alone a pig! Laughing Ex FFRR 4.2 Supercharged
Post #99183 23rd Dec 2011 9:27pm
bozmandb9
2013 Range Rover Vogue SE TDV8 Causeway Grey
I had a binding rear caliper, check your pads tomorrow! Apparently it's a common problem on 2005 cars. If it's on the n/s the pads will disappear without trace or warning, since the brake pad wear sensor is on the other side! 2012 SDV8 Vogue SE
Post #99187 23rd Dec 2011 9:36pm
Mikeyjd
Wales 2003 Range Rover SE Td6 Zambezi Silver
Could be the brake backplate touching the disc. mine used to rub slighty when driving but make a load noise like scratching a blackboard when reversing. No longer FF owner but still interested. Present car Jaguar XE
Previous car Td6 SE
Previous LR- Disco 300TDi Auto
Post #99213 23rd Dec 2011 10:51pm
Ludzy
Well it's deffinatley coming from the rear drivers side wheel. Some real heat coming from that wheel once I've stopped driving. And a strong smell of burning. Car vibrates like mad now when driving. I'm gonna take the wheel off next week and have alook see what I can see. If it is a stuck caliper does it mean the calipers knackered or do I just 'unstick' to put right?
Cheers
Post #99973 31st Dec 2011 7:51pm
Sticking caliper
Post #99974 31st Dec 2011 8:09pm
ebajema
Definitely caliper going, I had the same here !! Replaced both rear calipers and she was right as rain again Smile MY 2010 5.0 SC Galway green and sand interior!!
Post #99977 31st Dec 2011 8:45pm
billcyn
United Kingdom 2008 Range Rover Vogue TDV8 Epsom Green
Could someone confirm that the rear brake pad wear sensor on 2008 TDV8 is on the OFFSIDE as just found my offside rear pads are down to metal with badly scored disc - no warnings at all so assumed sensor was on NEARSIDE at rear. Hot metal particles also seem to have badly marked the N/S alloy wheel. So, new discs/pads and alloy refurb because of no warning signs. All other discs/pads seem fine!
Post #235640 17th Jan 2014 11:31pm
Pad warning wire is on the OSR pads but, only work if on the pad though! Thumbs Up
Post #235641 17th Jan 2014 11:48pm
This is why I hate sliding calliper brakes so much , such a shoddy cheep design and when things start to stick you get uneven wear on you pads and you could be oblivious to impending doom . That and the fact that the Land Rover warranty will only ever pay for one calliper Evil or Very Mad
Do Brembo do a rear calliper for the FullFat ? Sorely tempted if they do . 2008 MY Supercharged
Post #235648 18th Jan 2014 1:00am
billcyn
Thanks for your advice. It seems the sensor must be on the inner OSR pad and guess this hasn't worn sufficiently for the brake warning to operate so must be a siezed calliper. Made a real mess of the disc and wonder why this wasn't picked up during indie service and MOT (carried out before I bought the RR) 1,500 miles ago. Will certainly watch this weakness carefully in future. Is it possible to free off the slide pins or is a new calliper needed?
Post #235676 18th Jan 2014 1:36pm
TugRR
TRW rear calipers = garbage.
Had it recently on my ROS, so had it freed off by a garage.
I bought a full set of 2nd hand calipers for refurbishment & powder coating.
When dismantling these, it was clear to see the poor seal & bore corrosion Rolling Eyes
New caliper needed for you, I fear . . .
Thumbs Up Where do you go after one of these . . . ?
Post #235686 18th Jan 2014 4:43pm
