![]() | Home > Technical (L322) > gearbox thud |
lex99 Member Since: 26 Sep 2013 Location: canada Posts: 3 ![]() |
this is baaaad news! craig.. pm coming your way. |
SKOT Member Since: 24 Oct 2012 Location: Milton Keynes Posts: 792 ![]() ![]() ![]() |
Question. When a LR dealer / Indy (whoever) reflashes the gearbox software do the adaptions need to be reset too? Or can the new software be flashed without the adaption reset? 2006 4.2 SC
T24RES Member Since: 22 Nov 2010 Location: Henley-on-Thames Posts: 936 ![]() ![]() |
Ive re-read the whole thread, when reflashing software resetting the adaptation is required. |
The Big Gearbox places like A1 Premier Transmissions will do an overhaul for under £2k but complete rebuild £2.5-3k.
salb Member Since: 25 Feb 2012 Location: blackburn Posts: 332 ![]() ![]() ![]() |
hi,
auzzzie Member Since: 01 Oct 2014 Location: BC Posts: 1 ![]() ![]() ![]() |
Craig, I realize this is an old thread but I was hoping you might be able to PM me that information. I'm currently trying to decide if I should change the fluid in my 6HP26 or not. Very hard decision when multiple professionals have different opinions. If your opinion has changed or you have any info from LR you can pass on would be much appreciated. Cheers |
RR2008HSE Member Since: 06 Jan 2013 Location: British Columbia Posts: 2932 ![]() ![]() ![]() |
I'd be interested too.
Mikey Member Since: 10 Jan 2008 Location: Dundee Posts: 1847 ![]() ![]() |
Unnecessary quote removed
Before the 5.0 SC is shipped to Malaysia, I will have the ATF and filter replaced. Ideally first a Megaflush and then filter change so the oil is as clean/fresh as possible. MY 2010 5.0 SC Galway green and sand interior!!
Hi Mikey,
I do mine myself.
Stephen.125 Member Since: 25 Jun 2009 Location: Frodsham Posts: 1527 ![]() ![]() |
I'm so confused. I'm 500 miles away from 100k and wanted to get a megaflush and then filter swap/top up etc.
