Home > In Car Electronics (L322) > remote key fob HELP!
filthyliam
Hi all
if you see my other topic i have asked about something similar to this but this is the next development!
New car battery is now on working fine no issues have invested in a solar trickle charger for good measure though just incase car now starting no issues.
The only issue i now have is since the original battery went flat and has now been changed the remote locking/unlocking/tailgate release doesnt work. The light flashes when you press the buttons but nothing. the doors have to be unlocked/locked by key and the indicators flash when you do this. i have changed the battery in the remote and guess what its still the same the little red light on the key fob flashes but no action from any of the 3 buttons
any ideas at all chaps?
thanks in advance
Post #112297 10th Mar 2012 8:17pm
Jonno
United Kingdom 2012 Range Rover Autobiography 5.0 SC V8 Causeway Grey
Sounds like your key needs reprogramming. Follow these instructions ......it worked for me after a couple of goes!
Programming a new Key
Replacing a missing master key is quite expensive from Land Rover, try not to get sucked into the extra cost of "Dealer coding" You can do this yourself in 2 minutes by following the simple process below.
1) Get in and close all doors. Turn ignition on and off quickly and remove the key (all within about 5 seconds).
2) Within 30 seconds of turning the ignition off, while holding down the "unlock" button, press the "lock" button three times. Release the "unlock" button. (You may or may not get the confirmation from the door locks.) Holding the key at your head level provides best results as the key sensor is in the side window pillar.
3) Repeat for each key you want to initialize within 30 seconds after the last one you initialized (if you have more).
4) Right after doing the last key, quickly put the key back in the ignition and turn it on/off again to finalize.
Jonno 5.0 supercharged autobiography
Gone-4.4 Vogue Lpg now unmapped
4.6 HSET Turbo Lpg mapped
Gone-Defender 90 200tdi
Gone - 3.9 Sprintex supercharged LPG
Gone - 3.9 Vogue LPG
Post #112303 10th Mar 2012 8:41pm
filthyliam
ok thanks for this when you say "after a couple of times" i take it you did it once it didnt work and you had to try the process again then it worked?
is it normal for a key to need re programming after a flat battery or are their particular events that mean a key would need to be reprogrammed ?
Post #112318 10th Mar 2012 10:05pm
Jonno
Just wasn't quick enough the first go. The only reason I did this is because my spare key did as yours does when I first got the car. ie everthing worked except the central locking. Here's the link I got it from:
http://www.roverupgrades.com/Range_Rover_Hidden_menus.html
Post #112321 10th Mar 2012 10:15pm
filthyliam
Thanks for your help Jonno it worked first time ! just discovered that the spare key is doing the same so will do the same thing with this
Happy now all is working well again treated her to a full wash wax extra gloss shine and leather treatment as i was feeling good !
run out of tyre shine so dont want to post pics !
thanks again
Post #112497 11th Mar 2012 8:24pm
Jonno
Excellent..........Beats a trip to the stealers Very Happy 5.0 supercharged autobiography
Post #112522 11th Mar 2012 10:08pm
Lolo
Ireland 2011 Range Rover HSE TDV8 Santorini Black
just to add, u have to sync all keys at the same time, regardless whether one works or not.. Thumbs Up
Post #112530 11th Mar 2012 10:20pm
dan457brfc
thanks
Jonno,
Just done this and worked first time, thanks so much was expecting a big bill from the dealer!
Dan
Post #123560 25th May 2012 6:18am
DeRanged Rover
United Kingdom 2006 Range Rover Vogue SE Td6 Java Black
Hi guys,
Just tried to sync my new spare key using the method below.
However, when I put the key into the ignition it won't even turn for me to move on to the next steps Sad
Any ideas/suggestions?
Is it possible the new spare key hasn't been cut correctly? I notice there whereas the old key has a Y Shape notch at the end i.e. two diagonal cuts at the tip of the key where the cut channel starts, the new key only has one diagonal cut.
Cheers African Bush Junkie ... in London!
Stats:
2006 TD6 Vogue SE
1972-2015 DeRanged Rover
2001 P38 dHSE (SOLD)
Post #124819 3rd Jun 2012 11:26am
Jonno
Sounds like a wrong key to me.
Post #124824 3rd Jun 2012 12:12pm
stuboy00
Scotland 2006 Range Rover Vogue SE Td6 Java Black
Possibly the key has never been programmed with your rover I just got a brandnew key from LR and thought I was being smart trying to program it myself but it wont turn in the ignition (it works the locks) there must be something with it having a new transponder F**K IT you only live once
Post #124853 3rd Jun 2012 7:17pm
daveo
your new key is missing the transponder or it has not been programmed, that's why you cant turn the key as it does not see the transponder chip... V8 facelift Range Rover Autobiography 22" wheels.
Post #124855 3rd Jun 2012 7:53pm
stuboy00
No offence but I'm pretty sure that's what I just said LR wouldn't have sold me a key with no transponder F**K IT you only live once
Post #124858 3rd Jun 2012 8:25pm
daveo
i think you will find land rover will not sell a uncoded key, if the key was brought for your vin then ether it was not programmed correctley or it has been programmed with the wrong code, has your ignition been changed.. V8 facelift Range Rover Autobiography 22" wheels.
Post #124869 3rd Jun 2012 9:49pm
stuboy00
You can buy a key from LR uncoded if you know the correct people (i did say I thought I was being smart to try and code it myself) I now have a visit to make and get all my keys recoded £60 from LR F**K IT you only live once
Post #124882 3rd Jun 2012 10:38pm
