![]() | Home > Technical (L322) > IID Tool - Amplifiler ECU errors |
Hi all,
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35803 ![]() ![]() |
interested re the 15mm lowering, i gather thats in standard mode?
Hi Stan,
sounds good,
I believe our chief engineer, Christian, had this on his 2007. If I remember correctly it was chafed speaker wires under the RH front seat (directly in front of the BCM). Someone else had this too - was it Geoff (supershuttle)?
Thanks Steve |
supershuttle Member Since: 20 Mar 2011 Location: Lancashire Posts: 3940 ![]() ![]() ![]() |
I never got round to fixing anything but the two upper speakers in the rear doors are silent. I did take the passenger seat out but ran out of time and so had to put it all back without reaching a conclusion or fixing anything. Geoff |
Ah,,,well those will be the ones I'll check first then - oddly, I don't recall them ever running in my old 2006......had issues with the lower ones, and had them replaced.
All the speakers I could find seem to be working ..... how baffling |
Must be one of the ones you can't find because they are not making any sound |
<chuckle>
I think 13 is right.
Yep - but will do it again and get SWMBO to drive while I check each speaker |
