![]() | Home > In Car Electronics (L322) > SatNav Volume |
Press and hold the "musical note" button on the touch screen unit (under the on on/off). It will go to the AVC/Volume settings. Land Rover Addict
Mutley Member Since: 29 Jun 2011 Location: Reading, Berkshire Posts: 172 ![]() ![]() ![]() |
DMRR oh thank you so much I could not find it in the manual but I was probably nodding off as there is so much information.
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35861 ![]() ![]() |
also in nav mode you can increase the radio volume using the dash dial and the global volume via the steering wheel button.. ... - .- -.
Hi guys I have tried what you said about the settings but it has made no difference, i turned the nav button down to 1 & then next turn comes up loud as the radio really starting to |
sounds like there may be a fault if it doesnt adjust using my method... ... - .- -.
