Home > Technical (L322) > Check Coolant Level
mercuryf1
Malaysia 2015 Range Rover SVAutobiography 5.0 SC V8 Loire Blue
Check Coolant Level
I keep getting the message: 'Check Coolant Level' and the alert bell ringing each time I start driving. I checked under the bonnet and coolant level is normal - not low.
Any advice what could be triggering this false warning? if it is a faulty sensor, which sensor should I order? My car is in Malaysia and i have no access to a LR dealer. I can only order parts from UK to be sent here.
thanks guys. '01 1.8i Freelander. Grey/ grey
'06 4.2 S/C Buckingham Blue/ Parchment
'15 5.0 S/C SVA Loire blue/ Black
Post #113385 16th Mar 2012 3:54pm
http://www.fullfatrr.com/forum/topic7677.h...lant+level
hope this helps... ... - .- -.
Post #113388 16th Mar 2012 3:59pm
paul r
Hi,
Mine did this before I picked it up. The coolant mix wasn't right. Apparently the sensor is that sensitive, it can tell if the mix of coolant isnt concentrated enough!
Paul.
Post #113390 16th Mar 2012 4:04pm
mercuryf1
stan wrote:
http://www.fullfatrr.com/forum/topic7677.html?highlight=check+cheque+coolant+level
hope this helps...
Thanks Stan. I read that article after I did a search on coolant. However in my case, I am not low on coolant at all. '01 1.8i Freelander. Grey/ grey
Post #113391 16th Mar 2012 4:07pm
Mikeyjd
Wales 2003 Range Rover SE Td6 Zambezi Silver
As mentioned by Paul r. If the specific gravity of the coolant isn't correct even if rad is full, it will show "low coolant"? Maybe the coolant needs changing. No longer FF owner but still interested. Present car Jaguar XE
Previous car Td6 SE
Previous LR- Disco 300TDi Auto
Post #113395 16th Mar 2012 4:27pm
mercuryf1
paul r wrote:
Hi,
Paul.
is the correct mix at 50%? '01 1.8i Freelander. Grey/ grey
Post #113399 16th Mar 2012 5:30pm
