Home > Technical (L322) > TD6 battery drain located!! (fuse numbers enclosed) - HELP!
mrblonde
United Kingdom 2003 Range Rover Vogue Td6 Adriatic Blue
Thanks again nice
Will try the battery thing when I'm home Monday
You mentioned BCU in an earlier post? What's that stand for?
Cheers
Post #143627 29th Sep 2012 9:17am
Bcu, Body Control Unit. One of the numerous ECU's on the car that controls all the bits.
Post #143685 29th Sep 2012 4:20pm
Meerbusch
Germany 2017 Range Rover Vogue SDV8 Carpathian Grey
Hallo, I had the same problems years ago, my 2002 has no NAV, only Radio. First buyd the official cable to change under the panel with the new relais: NOTHING, then buyd the (in german IGEL), the part for the blower under the panel: NOTHING, then changed the original telefon connections from Nokia, and look: the battery is empty after 4 weeks, not after 4 days. What is about the alarm-system and the possibility to change the blowercable from always plus to ignition plus? Regards from germany, Uli L405 SDV8 2017 + Lancia Flavia Coupe 1964 + RRS L494 3.0 SDV6 + C220CDI Convertible 2021
Post #143725 30th Sep 2012 8:29am
