![]() | Home > Technical (L322) > Can i fully drop my glove box down to get to fuse box? |
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16395 ![]() ![]() ![]() |
No i dont think you can... Remove the glovebox is the only option depending on what your trying to do?
Lolo Member Since: 16 Feb 2012 Location: Leinster Posts: 608 ![]() ![]() ![]() |
Mne just falls down when I open it..! Can get access to fuse board no problem. Maybe press it little harder see if it goes down further for u. |
Stephen.125 Member Since: 25 Jun 2009 Location: Frodsham Posts: 1528 ![]() ![]() |
+1 not too bad a job to drop it though can be fiddly to get back if you disturb all the wires make sure nothing gets trapped behind there. |
mrblonde Member Since: 24 Jan 2012 Location: Cambs Posts: 766 ![]() ![]() ![]() |
cheers guys
nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3982 ![]() ![]() ![]() |
I used a pair of pointed pliers to push the blade fitting into each fuseway.
