Home > In Car Electronics (L322) > Venture cam not charging does anyone know about the fuse?
ambulancekidd
Scotland 2005 Range Rover Vogue Td6 Oslo Blue
When I bought my FFRR the venture cam was working well, but I think the dealership must have charged the venture cam up on another FFRR cos its certainly not charging. Can anyone here tell me where the fuse is located for the venture cam charger? Oh & which number fuse it is?
I'd also like to change the front side lights to LEDs. The lights that are on the car look awful & yellow next to the Bi Xenons. Which kind of bulbs do I need to buy?
I've also got a number plate bulb out, it appears to be a festoon bulb, I'd like to change them for an error free LED but what size are they? There are plenty on fleabay but there are different sizes.
All assistance is gratefully received...Robert. Bow down The reason women's minds are cleaner than a mans mind is that women change their minds more often!
When women say fine a mans in deep doodoo as fine has so many meanings.
Post #117324 12th Apr 2012 1:32pm
fuse position should be on rave somewhere, unless someone knows exactly which one it is ....
sidelights are 501 smd type, best place is ebay and there has been talk re this before if you need more info..... ... - .- -.
Post #117330 12th Apr 2012 2:44pm
ambulancekidd
Cheers Stan, I'll get the bulbs ordered up now. Very Happy
Robert. The reason women's minds are cleaner than a mans mind is that women change their minds more often!
Post #117354 12th Apr 2012 5:43pm
stu
United Kingdom 2012 Range Rover Vogue TDV8 Orkney Grey
are you sure that the venture cam isn't broken??
it is possible to fry the battery if it is left in the holder all the time.
you could also try switching it on to see if the green oval lights up, if it does delete the cam on the screen, then run the battery down and start all over again.
the car will try to charge the battery for a couple of mins, then ask you if you want to learn this camera, or something like that, it will then carry on charging the cam and you should see that battery level scrolling on the screen. Current: TDV8 (3.6) RRS HSE
Past: TDV8(4.4) Vogue
Discovery 3 Commercial
TDV8(3.6) Vogue
TD6 Vogue
D2 V8 ES
D1 V8 ES
RR Vogue Classic
Post #117359 12th Apr 2012 6:27pm
