![]() | Home > Technical (L322) > *HDC inactive* & *Air Susp Inactive* |
stuboy00 Member Since: 09 Feb 2012 Location: Glasgow Posts: 251 ![]() ![]() ![]() |
Hi guys i pulled into my drive last night with the rover on full lock to the right and the dreaded BONG sounded with *HDC inactive* & *Air Susp Inactive* displayed on the dash and dropped to access mode i left the car for a few mins then took it out for a run again, no errors displayed and the ride height was normal again until I put the car on full lock to the right again same thing happened the BONG and the message *HDC inactive* & *Air Susp Inactive* and lowered to access mode the car still drives etc and when you stop switch the ignition off then start up a few seconds later everything is clear and works normally could it be just a sensor as the suspension pump only runs for a couple of seconds on start up so I can't see it being the air pump or a leak? Anybody got any ideas?
CBH25 Member Since: 18 Feb 2012 Location: Sunshine Coast, Australia Posts: 82 ![]() ![]() ![]() |
This is exactly the set of errors I got last week when I was going around a wet round about and lost traction (turning hard right).
Hi there no loss of traction and no other issues apart from the suspension dropping to access mode but it is now happening every time the car is put into full right lock? Someone must have some ideas on this as I really don't want to visit my local stealer |
The loss of traction I was asking about was not after the error message, but during your full right lock manouver?
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35834 ![]() ![]() |
search "hdc inactive" with quote marks stu, loads on this.... ... - .- -. Y. O. L. O. . |
Hi Stan I did a bit of research before i posted and I'm going to check the speed sensor behind the wheel but apart from that there isnt really anything that is the same as what is happening with my rover ? It's gota new batteryby the way so it's not that either
from what you have said in your first post it does sound like the speed sensor... ... - .- -.
Andy3681 Member Since: 13 Jan 2012 Location: Newcastle under lyme/ Le Dorat Haute Vienne Posts: 912 ![]() ![]() ![]() |
Just a random thought I have been looking at my front height sensors as they are playing up and I cant bottom it yet but the height sensor is directly above the steering rack. The cable or plug are not getting caught or damaged on full lock? Mine was a blue one! |
Hi Stan no I didn't do anything after replacing the battery but this problem has only just occurred the new battery was installed in February? |
Hi Andy how do I get to the cable is it easily accessible (under or through the engine bay) do you have any pics for reference
Hi Stu
PS been reading previous threads because of my own fault but I think you need a fault reader to pinpoint the fault. The battery seems a fav talking point. good luck Mine was a blue one! |
hi guys ive had a look behind the passanger side wheel and found this now im pretty sure its not right as i would think that the bottom wire (white) should be covered somehow to protect it? can anybody tell me what it is? is this the speed sensor?
47p2 Member Since: 05 Oct 2010 Location: Gone Beyond, Subaru Posts: 8048 ![]() ![]() |
Brake pad sensor wire |
Guys for future reference knowledge, I had a faulty Brake Master Cylinder which completely fixed this error when replaced. L322 4.4 Vogue MY03 - Her name is Bulletproof .... you already know she's not |
