Home > Technical (L322) > red oil / fluid leaking
RRPhil
If transmission fluid is leaking into the bellhousing then the most obvious site is from the lip seal between the (stationary) oil pump housing and the (rotating) oil pump drive tube on the torque converter.
This seal is part of the transmission overhaul kit and so should have been replaced when the transmission was re-manufactured, and the pump drive tube should also have been reground when the torque converter was re-manufactured.
It’s possible to replace the seal without disassembling the transmission but the transmission would have to come out to get at it (approx. 5 hours of work).
The issue with the fluid relates to the different friction modifier packs used in different fluids. These not only determine the base friction coefficient levels but, more importantly, also the characteristic between static & dynamic coefficients for the clutches – particularly the torque converter lock-up clutch (which is designed to operate at a 3% slip level to eliminate torsional vibration). The 5HP24 transmission was developed around Esso (now Mobil) ATF LT71141 which provides a friction characteristic within the boundaries defined in the graph below
If a different friction modifier pack is used in the formulation of the fluid (like in Dexron for example) then the adaptions in the controller will be able to compensate to some extent for the different slip times (& modify the control pressures accordingly) but will eventually lead to clutch failure through inappropriate slip/energy levels.
For that reason, Mobil ATF LT71141 (a.k.a. ZF LifeGuardFluid 5) is the only fluid which should be used in the ZF 5HP24 transmission.
Just my opinion, obviously Very Happy
Phil
Post #121743 14th May 2012 2:07pm
woodchopper23
United Kingdom 2010 Range Rover Vogue TDV8 Ipanema Sand
Just thought I would update everyone, I have decided that the red fluid is infact coolant, which o am having to top up regularly . I'll have to find the leak when I get chance. Maybe the water pump . MY2010 TDV8 Vogue Ipanema Sand
2002 V8 Vogue Oslo Blue - Gone.
Post #139990 7th Sep 2012 11:55am
