Home > Technical (L322) > red oil / fluid leaking
woodchopper23
United Kingdom 2010 Range Rover Vogue TDV8 Ipanema Sand
Hi folks,
I have a leak somewhere and I am trying to find it. I have noticed red oil / fluid collecting on the subframe below where the engine mates to the gearbox...I could not identify where the fresh leak was coming from as all of the componats above seemed dry??
Does anyone know what fluids in the L322 petrol are red?
Cheers gents MY2010 TDV8 Vogue Ipanema Sand
2002 V8 Vogue Oslo Blue - Gone.
Post #120151 3rd May 2012 5:16pm
Power steering possibly?
Post #120152 3rd May 2012 5:17pm
woodchopper23
The steering fluid appears to be a shade of yellow. I am wondering if it could be the gearbox oil, so might check that tommorrow to see if the level is down MY2010 TDV8 Vogue Ipanema Sand
Post #120153 3rd May 2012 5:21pm
Gearbox oil is a honey colour when new then black with age. Could be coolant as its that far back. Take your cap of the reservoir with the engine running (not hot) and look at the telltail jet. Should be either green/blue or red/orange. [img]http://www.fuelly.com/driver/rob2529/range-rover[img/]
Post #120154 3rd May 2012 5:24pm
simonmanx
Isle Of Man 2005 Range Rover Vogue SE Td6 Java Black
red could be transmission fluid try running the car whilst in park and check cooler lines running from the passenger side of the gearbox running up to the side of the engine if it is the cooler pipes they maybe only leaking under pressure, but if it tastes sweet it could be antifreeze
Post #120155 3rd May 2012 5:26pm
simonmanx
ooops thought it was a TD6 for some reason so pipes may not be in the same place
Post #120156 3rd May 2012 5:27pm
woodchopper23
just checked the coolant and it is red, but it seems too thin to be the be the oily red substance collecting on the afore mentioned subframe under the joing between gearbox and engine MY2010 TDV8 Vogue Ipanema Sand
Post #120157 3rd May 2012 5:36pm
The front diff is up there
Post #120158 3rd May 2012 5:40pm
Sounds like power steering fluid, is the diff oil red? There is nothing that can't be fixed with a hammer😜😜
Post #120162 3rd May 2012 6:48pm
woodchopper23
the front diff appears to be ok... no sign of leaks. Ill get under it again tommorrow for a good look. i looked at the power steering fuid under the bonnet and it looks more like green that red, so i do not think that it is the cause of the leak.
is there any fluid/ oil in the connection between gearbox bellhousing and engine?
I cannot think where it is coming from, as the crossmember is wet, but all above is dry ?? MY2010 TDV8 Vogue Ipanema Sand
Post #120165 3rd May 2012 6:55pm
When your under there take your camera as well. I had a coolant leak from the top of the engine at the back and it was running down round the bell housing looking like something from the gearbox. As the coolant was hot it had become quite sticky as the residue lost the fluid that makes it up and was more concentrated. Have you felt what the fluid/oil is like to the touch? Does it leave a stain on your drive etc? [img]http://www.fuelly.com/driver/rob2529/range-rover[img/]
Post #120189 3rd May 2012 10:17pm
simonmanx
torque converter seal ?? you should be able to check this by looking inside the bell housing via the rubber cap in the bell housing
Post #120202 3rd May 2012 11:08pm
RRPhil
If you have red fluid coming out of a 5HP24 then someone's put Dexron in it, which means you've got much bigger problems than just a leak.....
Phil
Post #120299 4th May 2012 4:27pm
jim2RRs
United States 2005 Range Rover HSE 4.4 V8 Chawton White
What color is your coolant?
What Rob says...
There's several coolant lines on the back of the block, and they do leak and need replaced.
Before a catastrophic blow-out, they will drip under pressure.
The liquid hits the top of the bell housing and runs down around it to drip on the floor, right about where the engine meets the transmission.
Replacement is not hard to do.
Raise the bonnet to the service position (straight up).
Remove the engine cover.
Climb on up in there with a flashlight, or a torch if you prefer, and look at the hoses on the back of the block.
I had a leaking one there, took less than 30 minutes to replace it.
Of course, the parts monkies at the dealership had no idea what I was talking about.
Happily, I showed them the part I needed on their MicroCat, and all was well with the world. Jim
2000 NAS HSE
2005 NAS HSE
Post #120380 4th May 2012 11:30pm
woodchopper23
Hi folks , just to update,
I've had a further look at the red fluid and it seems to be coming from the inside of the bellhousing possibly. Is this some kind of shaft seal inside of the bellhousing. I will have to check the rave later to find drawings and correct terminology. Rrphil mentioned about incorrect oil. I will have to get the gearbox oil fill / level plug out to confirm the oil is red. I bought it Feb just gone and it had recently been rebuilt (approx 5k ago now) by a company called sw transmissions somewhere down south I believe . I could not find a number from them to confirm anything, although I have not looked hard.
If it turns out the oil is incorrect is it a case of just draining, flushing , refilling, changing filter of course? I suppose that is all that can be done... Or will it surfice with the "red" oil inside?
I had the engine cover off and the bonnet upright 'tother day to change the rocker cover gaskets both port and starboard, and checked all of the hosesx which appeared to be.nice and soft and relitivley new. Possibly they have been changed in recent history.
Thanks for the input so far folks. And appologies for typos and spelling, as I am on ky phone, which has small buttons! MY2010 TDV8 Vogue Ipanema Sand
Post #121665 14th May 2012 7:15am
