![]() | Home > In Car Electronics (L322) > Digital TV tuner. |
| jfb1977 Member Since: 29 Apr 2012 Location: Bury St Edmunds Posts: 563
Sorry for all of these new owner questions (I haven't picked my car up yet and I've got too much time on my hands, clearly) but on a 2007MY car will the TV be digital?
| Katash Member Since: 10 Apr 2011 Location: Hereford Posts: 700
I looked at a 56 plate (Dec 06) 07MY (Terrain response etc ...) SC 4 weeks ago and it had an analogue tuner and old style key.
| Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16403
I think all TV's are analogue upto 09my... Please correct me if anyone knows differently?
| TheAllSeeingPie Member Since: 18 Apr 2012 Location: Leeds Posts: 848
My 07 Supercharged has digital TV, although I couldn't say if it was factory fit. Also it's a bit stuttery too so I never use it. |
| simon1233 Member Since: 13 Jun 2011 Location: Leyland, sometimes Darmstadt Posts: 650
Craig - 57plate (MY08) TDV8 has hybrid tuner as standard |
I haven't picked my car up yet, but when I do - what's the easiest way to tell if it's digital or analogue? |
Craig |
Have a search in the wiki for its location, the hybrid is half the thickness of the analogue... If you need/want a hybrid one, send me a PM... Craig |
I did have a rummage Craig, but I must be being thick / blind as I can't find anything.
| stu Member Since: 04 May 2011 Location: Richmond North Yorkshire Posts: 927
if you look in the cubby hole that houses the nav drive, look down into the hole and you will see a silver box with a couple of fakir type arial connectors a most conector and a power connector, obviosly a silver box. that is the TV Tuner. you should be able to read the label on it to and it will say hybrid tuner if it's digital.
| DMRR Member Since: 14 Apr 2010 Location: Northamptonshire Posts: 2027
My 56 plate has hybrid Land Rover Addict
Thanks guys. Past (too many to list, but a few favs)...
Does yours have RSE?
Yes. It does. Past (too many to list, but a few favs)...
