Home > Technical (L322) > ZF 5HP24 valve block available for substitution test
RRPhil
If anyone’s having problems with their ZF 5HP24 transmission (’02–‘05MY 4.4 V8 models) which they believe may be valve block related then I have a spare valve block that I’ve just rebuilt and checked which you’d be welcome to try to see if it fixes the problem. If you’re a regular contributor to the forum then no deposit is required, if you’d just pick up the bill for the postage costs (approx. £20 each way).
If the valve block fixes your problem and you’d like to keep it then I’m sure we can come to an arrangement. If it doesn’t fix the problem, just return it and at least you’ve eliminated your valve block as the cause. The unit includes the internal wiring loom & speed sensors.
Phil
Post #121487 12th May 2012 4:11pm
Very generous offer Phil Thumbs Up
Post #121494 12th May 2012 5:20pm
as above kudos for being so generous Phil Smile FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
Post #121499 12th May 2012 6:27pm
Kudos to you Phill. You really are a true gent and gearbox guru! [img]http://www.fuelly.com/driver/rob2529/range-rover[img/]
Post #121531 12th May 2012 9:48pm
woodchopper23
United Kingdom 2010 Range Rover Vogue TDV8 Ipanema Sand
That's an awful nice lookin Thumbs Up hg piece of machinery! MY2010 TDV8 Vogue Ipanema Sand
2002 V8 Vogue Oslo Blue - Gone.
Post #122421 17th May 2012 4:32pm
woodchopper23
*looking MY2010 TDV8 Vogue Ipanema Sand
Post #122422 17th May 2012 4:32pm
