![]() | Home > Technical (L322) > wows after removing door mirror |
woodchopper23 Member Since: 20 Jan 2012 Location: cumbria Posts: 259 ![]() ![]() ![]() |
Fck knows. Sorry my reply is no help. MY2010 TDV8 Vogue Ipanema Sand
Dave
daveo Member Since: 21 Oct 2009 Location: london Posts: 2307 ![]() ![]() ![]() |
i will have to whip off the door card again, need to look for the door switch as well,it must of fell behind the door foil.. V8 facelift Range Rover Autobiography 22" wheels.
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16395 ![]() ![]() ![]() |
Which mirror Dave? Driver or pass?
Well i have had 2 new mirrors fitted curtsy of the insurance company, and it started when i noticed the access button was not working, they took the driver door card of and i pointed out that they have plugged the chromatic
There is three plugs in a plastic holder mounted vertically tweeter speaker wire, anti trap for window and the chromatic/puddle lamp plug so it must be around there somewhere... But, if they plugged the wrong plug in you may have problems unfortunately!
well they are aware they put the wrong plug in the door switch module, they put the chromatic plug instead of the ibus plug, funny i thought they would different plugs to stop something like that happening, funny i did notice two other plugs not connected. i am hoping one of the other is the door switch.
Sounds like a good job done Dave |
mattstevenson2005 Member Since: 01 Jan 2011 Location: Manchester, UK Posts: 737 ![]() ![]() ![]() |
did you fit the newer style mirrors? if so did you have any trouble with getting all the systems to work e.g. dimming, folding etc....
Seems like JLR/BMW are not familiar with the original Murphy's law : If a part can be mounted two ways, a correct and incorrect way, then there will always be someone installing the part incorrectly at some point in time.
