Home > Maintenance & Mods (L322) > Fitting Overfinch rear roof spoiler for my 07 S/C
cuda
found one on Pistonheads - guy's offering to fit it quoting 'upper tailgate comes off, 4 10mm bolts, remove exsiting brake lense, swop the brake light lead connector, fit spoiler onto upper tailgate whist its off the car, malke sure its nice and secure, re-fit, quite straight forward'.
is it this simple and what about the rear facing camera - does that get affected or does is attach to the spoiler?
thanks
Cuda 07 S/C in Java with Ebony
Post #124364 30th May 2012 2:55pm
jfb1977
England 2011 Range Rover Vogue SE 4.4 V8 Santorini Black
Embarassed Shocked Past (too many to list, but a few favs)...
2007 Porsche 997 C2S Coupe
2007 FFRR 4.2 S/C
2012 Jag XKR 5.0 S/C
2014 Merc SL500 AMG 4.7 V8 BiTurbo (remapped to 560BHP)
2011 FFRR 4.4 TDV8 Vogue SE - Overfinch Conversion
2012 Porsche Cayenne Turbo
2018 AMG C63S Estate
2015 Mercedes GLE63S
2017 Maserati Levante Diesel
2017 Audi A6 Avant 3.0 Black Edition
Post #124391 30th May 2012 5:43pm
jfb1977
Should be a doddle.
The process is the same as when you need to get to the rear washer - undo 4 bolts, lift off brake light housing etc.
It's literally 4 bolts which are easy to get to with the boot open, then lift off the top section with the brake light in it, unplug and then the reverse the process to refit.
Do a search for how to repair the rear windscreen washer and you should find some pics I think... Thumbs Up Past (too many to list, but a few favs)...
2007 FFRR 4.2 S/C
Post #124393 30th May 2012 5:44pm
cuda
ok thanks so that doesn't interfere with the camera? 07 S/C in Java with Ebony
Post #124395 30th May 2012 5:47pm
jfb1977
Ahhhh. You'll have to check with the seller about the camera - I would assume that if the spoiler has been designed properly, it will have a mounting bracket / holes for the camera and you'd just swap it over from your current spoiler to the new one.
If they haven't allowed for it then it's a big oversight as most L322s have a camera.
Can you get any pics of the new spoiler so you can check? Past (too many to list, but a few favs)...
2007 FFRR 4.2 S/C
Post #124397 30th May 2012 5:57pm
cuda
i asked the seller whether it interferes with the camera and he says:
quote
Good question, it doesn't as it sits above the camera without any modification or inconvenience. That is why Overfinch are the best Land Rover tuning company in the World. They are very clever and design these things with every item on Range Rovers in mind.
unquote
willl have a look this eve at where the camer is etc..
thanks so far 07 S/C in Java with Ebony
Post #124399 30th May 2012 6:00pm
VaguelyVogue
United Kingdom 2006 Range Rover Vogue Td6 Buckingham Blue
A quick search revealed some useful photographs of rear spoiler removal and camera changing http://www.fullfatrr.com/forum/topic4621.html (but I don't know where the plug to the camera wires is).
Post #124400 30th May 2012 6:01pm
cuda
i have pics of the spoiler but no idea how to post on here as there's no browse button like on p'heads...!
[/img] 07 S/C in Java with Ebony
Post #124402 30th May 2012 6:05pm
have a look in site announcements for picture posting how to.. ... - .- -.
Post #124406 30th May 2012 6:11pm
cuda
jeez thats alot of admin just to post a pic... 07 S/C in Java with Ebony
Post #124407 30th May 2012 6:21pm
Spend time doing admin, or spend money on a spoiler you can't use! Tough call! Mr. Green Whistle Got - 2017 SDV8 Autobiography in Loire Blue
Post #124418 30th May 2012 7:15pm
quote
unquote
thanks so far
If its a proper Overfinch spoiler then you have to remove your 3rd brake light and fit the spoiler in the same holes after fitting the brake light back into the same size and shape hole/recess in the spoiler... So a kind of piggy back affair if that makes sense... You'll need to remove the inner top trim panel that covers the wiper motor to unplug/replug all the wiring for the brake light and camera etc...
Craig Thumbs Up
Post #124436 30th May 2012 8:56pm
Wee-socks
Scotland 2007 Range Rover Vogue SE TDV8 Java Black
Hi I am new on here and noticed your post!!! I fitted one to my RR last week and it is straight forward if you need any info or pics pm me.....
Post #124457 30th May 2012 10:44pm
cuda
well just spent 15 mins following the guide and trying to upload an image to my new gallery and it keeps on showing up as empty so not gonna waste any more time on that unless a moderator can pm me how... 07 S/C in Java with Ebony
Post #124469 31st May 2012 7:33am
cuda
Tried again - lets hope this works...
Does this look like genuine Overfinch spoiler? Cant see where the camera woudl fit...
Haven't bought it yet, mind. 07 S/C in Java with Ebony
Post #124471 31st May 2012 7:41am
