![]() | Home > Maintenance & Mods (L322) > Air Filter |
Stick with the original |
| ebajema Member Since: 24 Mar 2011 Location: New Plymouth Posts: 4782
I put a K&N in and to be honest, absolutely no gain whatsoever. Only reason for me is that the normal filters cost more than a K&N over here and Harmatan can be quite dusty so I want to be able to clean them after each Harmatan if needed. MY 2010 5.0 SC Galway green and sand interior!!
| dannyp15 Member Since: 21 Sep 2011 Location: essex Posts: 244
original |
| daxon Member Since: 24 Mar 2012 Location: ontario Posts: 2
Go with original, K&N might be useful for a carbed car but can foul your
| northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8790
How about an open sponge type like pipercross, they dont need oiling.
| Pedrochellie Member Since: 23 Feb 2012 Location: Surrey Posts: 82
Just seen this:
| vnitos Member Since: 18 Nov 2010 Location: pretoria Posts: 390
Most if not all who did the conversion on 2002-2004 models to 2006 and later are using k&n type cone air filter |
| Dolphinboy Member Since: 07 Dec 2009 Location: Bristol Posts: 3284
I think that's because space is tight after the conversion and the k&n fits the best. |
| Andy3681 Member Since: 13 Jan 2012 Location: Newcastle under lyme/ Le Dorat Haute Vienne Posts: 912
Run my td6 with a K & N tend to put them on all my cars by habit. No noticeable performance gain but it does seem to change up earlier and seen a small mpg increase only negative in sounds bit louder! Mine was a blue one! |
| The Brains Trust Member Since: 23 Sep 2011 Location: Melbourne Posts: 155
K&N's are only good at keeping small rodents out of the engine. If you actually want to keep dust out of it, stick with the original. |
