Home > In Car Electronics (L322) > GPS has line through it
Elena
United Kingdom 2006 Range Rover Vogue Td6 Java Black
Hi all
The GPS box on my touch screen has a l line through it and the Sat Nav does not know where it is, please help.
Cheers
Elena
Post #125669 11th Jun 2012 1:56pm
take the disc out and reload, or do a battery disconnection....might help. ... - .- -.
Post #125671 11th Jun 2012 1:59pm
Elena
Hi Stan
Popped the disc out and back in now i have line through the GPS and TMC. If I disconnect the battery do I have to do the sequence with the jump lead etc again.
Cheers
Post #125770 12th Jun 2012 9:16am
the battery disconnection procedure is in the wiki, here's the link http://www.fullfatrr.com/wiki/Battery_dis-connection_procedure ... - .- -.
Post #125771 12th Jun 2012 9:26am
supershuttle
TMC might just be you are out of range of a suitable Radio station obviously for the GPS bit to function you need to have sight of the sky. Both these problems could be caused simply by location I.e. in a garage. Geoff
Post #125775 12th Jun 2012 9:58am
JustinP
Re-tune the tmc station should sort out the TMC issue, my car regularly selects Heart FM for the tmc service, probably because Heart FM are abusing the TMC system.
Post #125862 12th Jun 2012 7:26pm
Elena
Okay, TMC now sorted but after battery disconnection etc still have a line through the GPS, any other ideas please.
Regards
Elena
Post #126448 16th Jun 2012 12:01pm
all i can think of is to check and recheck all the connections relating to the nav unit. ... - .- -.
Post #126457 16th Jun 2012 1:45pm
Elena
cheers Stan, now the rain has stopped I will have a look
Post #126554 17th Jun 2012 3:24pm
Elena
All connections look fine, as far as I can see. The GPS was definitely working before the battery was changed. The manual does state that a battery disconnection can cause this fault but it doesn't tell you what to do about it. Big Cry
Post #127468 24th Jun 2012 10:41pm
