Home > Maintenance & Mods (L322) > Heater fan lubrication ? |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 34919 |
it appears that the vents just pull out so possibly you might gain access to the motor that way..
20th Jun 2012 2:24pm |
Don't be silly Stan, it's a Range Rover...
20th Jun 2012 2:32pm |
Contraband Member Since: 08 Nov 2010 Location: FIFE Posts: 3697 |
Previously..
20th Jun 2012 2:37pm |
.........sharp today john.. ... - .- -.
20th Jun 2012 2:38pm |
You mean blunt and to the point Stan |
20th Jun 2012 3:04pm |
Rob2529 Member Since: 22 Nov 2010 Location: Wirral, uk Posts: 1470 |
Back to the OP the fans can be accessed a bit if you take out the pollen filter box in the engine bay, remove the seal and then 2x 13mm nuts and just pulls out. You can then get access to the two. If holes and the fan inside. [img]http://www.fuelly.com/driver/rob2529/range-rover[img/]
20th Jun 2012 5:11pm |
^^^ Spoilsport |
20th Jun 2012 6:38pm |
jim2RRs Member Since: 07 Feb 2012 Location: Genesee, Colorado Posts: 147 |
However you get to the fans, you might want to actually use a LUBRICANT instead of WD-40.
20th Jun 2012 8:06pm |
According to RAVE, fan motor access is 5 steps, as follows:
20th Jun 2012 8:31pm |
So my post was almost correct then |
20th Jun 2012 8:38pm |
pretty close.
20th Jun 2012 9:09pm |
so it'll be squirting wd40 into the intake then... ... - .- -.
20th Jun 2012 10:31pm |
Johnte Member Since: 23 Aug 2010 Location: North Yorkshire Posts: 733 |
I think it'll be putting it in position 2 onwards, where it's nice and quiet |
20th Jun 2012 11:02pm |
