![]() | Home > Technical (L322) > Tuning box (removal) |
Andy3681 Member Since: 13 Jan 2012 Location: Newcastle under lyme/ Le Dorat Haute Vienne Posts: 912 ![]() ![]() ![]() |
At A guess it will just plug into the fuel rail pressure sensor right at the top back of the engine.
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35805 ![]() ![]() |
i think its just a matter of unplugging it...remove the plastic top cover over the engine and you should see where the 'end' of the tuning box cable goes... ... - .- -.
47p2 Member Since: 05 Oct 2010 Location: Gone Beyond, Subaru Posts: 8048 ![]() ![]() |
To access the rear of the engine remove the heater scuttle where the pollen filter is. |
You may not like the resulting drop in performance..... |
Johnte Member Since: 23 Aug 2010 Location: North Yorkshire Posts: 745 ![]() ![]() |
@ Stan - The other end of the cable just disappears into the loom, I just didn't know where the plug went that is currently plugged into the box ( Does that make sense )
will the engine run if you just unplug it john? ... - .- -.
Didn't like to try in case I damaged anything ... |
i dont think you will...from your picture it looks like the 'other' end of the cable has been hard wired into the loom..
OK Thanks |
