Home > Technical (L322) > Transfer box neutral warning message
misteralz
Scotland 2003 Range Rover Vogue Td6 Buckingham Blue
Flashed up earlier on, but didn't seem to be accompanied by loss of drive. Luckily I was just outside my work, so backed off the throttle and coasted in. Reversed into my usual space no problem, pulled it forward again, reversed again, no problem. Just taken it into the workshop and back out again (different story) and there were no problems there, either. Glitch in the matrix, or should I now be worried? 2003 Vogue TD6/1992 Classic 300TDi/2x 1991 Golf GTI/1966 Volkswagen Kombi/2x 1968 Volkswagen Kombi/Probably something I've forgotten...
Post #130460 11th Jul 2012 12:47pm
VaguelyVogue
United Kingdom 2006 Range Rover Vogue Td6 Buckingham Blue
You didn't knock the Hi/Low range switch by mistake (causing the "Put gearbox into neutral" message) ?
Post #130471 11th Jul 2012 1:58pm
misteralz
No, I've done that deliberately in traffic and seen that message before. This definitely said 'Transfer Box Neutral'. Just flashed up for a moment and was gone. 2003 Vogue TD6/1992 Classic 300TDi/2x 1991 Golf GTI/1966 Volkswagen Kombi/2x 1968 Volkswagen Kombi/Probably something I've forgotten...
Post #130489 11th Jul 2012 3:10pm
Andy3681
United Kingdom 2005 Range Rover Vogue Td6 Cairns Blue
Its just messing with you cause it can Shocked
Seriously after all the rain etc it could be a bit of damp or somthing like that just see if it does it again.
Then panic Mine was a blue one! Smile
Post #130491 11th Jul 2012 3:32pm
misteralz
Laughing I'll go with that. Need to change the transfer box fluid anyway, be interesting to see what comes out... 2003 Vogue TD6/1992 Classic 300TDi/2x 1991 Golf GTI/1966 Volkswagen Kombi/2x 1968 Volkswagen Kombi/Probably something I've forgotten...
Post #130502 11th Jul 2012 4:07pm
It will be a muddy brown colour Shocked
Post #130504 11th Jul 2012 4:15pm
Mine looked more like black treacle in colour, nearly black but still translucent, but not that thick in consistency Smile .
Post #130510 11th Jul 2012 4:29pm
Andy3681
And the transfer box fluid? Mine was a blue one! Smile
Post #130511 11th Jul 2012 4:30pm
Laughing ... - .- -.
Post #130512 11th Jul 2012 4:31pm
touché Laughing .
Post #130559 11th Jul 2012 6:55pm
KARMANN
2002 Range Rover Vogue 4.4 V8 Java Black
If this appears its more than likely to be the electric motor that actuates the hi low. Mine has done it from time to time-ive removed it. Tested it on a bench and replaced it and it works fine. Theres a sensor inside it thats suppposed to communicate pretty mush saying what position its in and if its working. This sometimes plays up causing this issue. As i said before-three bolts undoes it and one electrical connector. Just by removing it putting 12v across it a little lubrication and refitting it has always worked for me. the other option is to pay £700ish for a new one. The sensors cant be purchased seperately.
Fraser
Post #131701 18th Jul 2012 12:11am
Bob the B
United Kingdom 2004 Range Rover Vogue Td6 Santorini Black
Just started to have this problem myself Sad
Googled it and came back with a couple of solutions from a different forums.
http://www.rangerovers.net/forum/6-range-r...nging.html
http://www.justanswer.com/car/2rs18-04-ran...ng-on.html
I havn't tried to sort this myself yet but its on the list of things to do.
Stan/Martin I apologise if Im not suposed to direct people to other forums Thumbs Up
Post #134140 3rd Aug 2012 12:16am
RRPhil
That message should only appear if you insert a fuse into position 37 to prevent the transmission output shaft being driven if the car is towed on all four wheels.
It’s probably just a glitch or battery voltage thing but it could also be a sign that the carbon tracks in the shift motor’s rotary potentiometer are starting to oxidise/corrode (a very common problem as, inevitably, most L322s just stay in high range for years on end so the tracks never get used/cleaned)
Phil
Post #134222 3rd Aug 2012 6:03pm
socialrover
Hi Phill ,
apart from the annoying Bong, am I ok to still drive it around ( perhaps with some ear plugs ha ?) .
I can't get it into the garage for 3 weeks !
Kind regards
Post #520181 30th Jun 2019 8:17pm
