Home > Maintenance & Mods (L322) > Plenty refrigerant but no cold aircon: EDITED - and no heat!
Simes
United Kingdom 2011 Range Rover Autobiography Black TDV8 Barolo Black
misteralz wrote:
Thanks - looks a really easy job. Where's the best place to get a new FSR?
You say you can get all the fan speeds - so that means it's not the resistor.
You really need to get it checked out properly. See if there are any fault codes stored anywhere. It sounds like blend motors have stopped working - which could be because the HEVAC system has faulted and shutdown.
Post #133207 27th Jul 2012 10:59am
Simes
Joe90 wrote:
I was out last night at 22:30 and aircon was still blasting away at 22 degrees setting
He's in Scotland though - it will still be calling for max heat to thaw the permafrost up there.
Very Happy
Post #133208 27th Jul 2012 11:01am
misteralz
Scotland 2003 Range Rover Vogue Td6 Buckingham Blue
Aye, got someone looking at it next week, hopefully. Gonna choose to ignore the other comment. 2003 Vogue TD6/1992 Classic 300TDi/2x 1991 Golf GTI/1966 Volkswagen Kombi/2x 1968 Volkswagen Kombi/Probably something I've forgotten...
Post #133209 27th Jul 2012 11:03am
Simes
I think you've no option - unless you can read the fault codes yourself you are working in the dark. Even if you fix whatever is broken, it still might not work until it's been reset. Range Rovers are like that.
Post #133211 27th Jul 2012 11:11am
Tuts
misteralz wrote:
Seems it's probably not an aircon issue at all. Plenty refrigerant in both sides - yeah, checked with a gauge - and checking the temperatures from the vents with my hand-held IR temp gauge sees to real variation in temperature from 16 to whatever the max is on the dial... So it's a control issue which is a bit of a Censored . So, first things first, are there any simple checks I can perform? I can get all the fan speeds and the umpteen buttons to control the airflow work, so what's likely to be wrong?
Does it only go down to 16 degrees? After mine was re-gassed it was measured at the vents with a thermometer and goes down to 4.4 degrees 2003 Vogue 4.4 V8 Java Black
Post #133220 27th Jul 2012 12:01pm
Simes
16 degrees is the coldest you can select on the dial - that's to set the internal temp of the car to 16 - obviously the air from the vents will be colder than this, but how cold will depend a little on ambient temperature.
Post #133222 27th Jul 2012 12:12pm
Tuts
Yeah I know but misteralz says that IS the temp at the vents
Post #133229 27th Jul 2012 12:48pm
misteralz
Yeah, the temperature from the vents remained reasonably static wherever the dials were rotated to - be that 16 or 28 degrees, the temperature coming out of the vents remained around 23 degrees. Confused 2003 Vogue TD6/1992 Classic 300TDi/2x 1991 Golf GTI/1966 Volkswagen Kombi/2x 1968 Volkswagen Kombi/Probably something I've forgotten...
Post #133241 27th Jul 2012 1:50pm
