![]() | Home > Off Topic > Dell Windows 7 licence keys |
Budgie Member Since: 09 Jul 2012 Location: Stornoway Posts: 267 ![]() ![]() |
Try searching for a Windows 7 OME licence.
Hi Ali,
mrd1990 Member Since: 01 Jun 2011 Location: N. Wales Posts: 267 ![]() ![]() ![]() |
be careful there is no spyware installed.
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Bordeaux / Andorra Posts: 8079 ![]() ![]() ![]() |
Looks like a 'legit' install - but with a temporary key
No problems alistair |
A1GSS Member Since: 24 Dec 2010 Location: Saffron Walden, Essex Posts: 1973 ![]() ![]() |
Thanks kingpleb
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6424 ![]() ![]() |
Why can't you upgrade the bios?
Dell don't upgrade the BIOS for older machined - the one I'm on at the moment is a GX620 & Dell only have BIOS A11 available for download. Apparently only versions A15 or later work with OEM Win 7.
Is this right? I've got a 7 year old Dell D600 laptop running Windows 7 perfectly well... Graham
It depends on which version of Win 7 & where you got it from.
Windows Loader |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7971 ![]() ![]() ![]() |
+1......... 2011 Range Rover Vogue SE 4.4 TDV8
Katash Member Since: 10 Apr 2011 Location: Hereford Posts: 700 ![]() ![]() ![]() |
Be aware if you put a custom BIOS on you'll likely reset all the settings too, if your not sure how to customise a BIOS it can be a minefield - things like memory timings, CPU settings even voltages can (but are normally locked down) changed, apologies if you already know how to do this tho.
