Home > Maintenance & Mods (L322) > HDC, Air Suspension & hand brake and ABS light?
Glideman
Location: Stood next to a broken down Range Rover in Darwen
United Kingdom 2003 Range Rover Vogue 4.4 V8 Zambezi Silver
I washed the car the other day & decided to give under the bonnet a quick clean. I wiped the engine & inner wings with a wet sponge & then started the engine. The center L.E.D. display said
Quote:
HDC, Air Suspension inactive
and hand brake and ABS light are both on and the stability control light (orange squiggle in middle of clocks?) are all lit up like a Christmas tree Rolling Eyes
The car rides OK but makes strange movements when you first turn the key. It's not like when one of the suspension struts went & the car was rock hard. The other day the hand brake light went out then it came back on and stayed on.
I did assume a car made to wade in deep water would be OK with a light wetting under the bonnet but obviously not. Has anyone got any ideas what to check & will it need to be reset at the dealers again?
Maybe it would be worth buying my own reset tool as the car has been to the dealers 6 times this year already to have the computer reset after having one thing or another fixed. Range Rover 4.4 V8 Vogue
Post #134104 2nd Aug 2012 7:07pm
leave it to dry for a while then see if the lights are still there.. ... - .- -.
Post #134105 2nd Aug 2012 7:09pm
Glideman
Hi Stan, thanks for the reply. It's been over a week now & no change. Drove the car 60 miles today with all the lights stil lit & it drives fine. Maybe it's just a sensor? Oh and the steering went VERY light when it first happend but this seems to have sorted itself out Confused
If it was any other car I wouldn't drive it with the dash lit up but the car seems to have something wrong permanently & I just don't have time to leave it with the dealer every few weeks. Range Rover 4.4 V8 Vogue
Post #134108 2nd Aug 2012 7:14pm
dont know why you're having the lights unless you dis-connected the battery and didnt reset the steering parameters....
your suggestion of getting a reset tool is a good one..something like the IIDTool lets you play with the CCF as well.. ... - .- -.
Post #134109 2nd Aug 2012 7:26pm
Saint.v8
Location: UK< Surrey - Near the Middle Close to Some Green Bits
Try disconnecting the battery waiting 15 minutes then reconnect...
Carryout the steering angle sensor reset by turning full lock to the left then full ock to the right then back to centre....
That may kick it back into action...
I had similar and it turned out to be a dodgy ABS sensor....
The ABS system in connected to the same data bus as the EAS....so a fault in the ABS system usualy freezes the EAS too (annoyingly).
The reason it knocks out the HDC & DSC too, is those two systems also use the ABS sensor information to maintain control down hills and to monitor the traction of all 4 wheels for the DSC.
Getting a diag tool is a fab plan
Post #134111 2nd Aug 2012 7:44pm
Glideman
Thanks for all the help guys, I'm off to disconnect the battery to see if that helps and have just Googled the
Integrated interface diagnostic tool (IID Tool) for RANGE ROVER L322 - FOR 2002-2005 £231.25 exc. VAT
Seems a bit pricey for a small box? Does anyone do a cheaper version which does the same?
Post #134112 2nd Aug 2012 7:52pm
piecost76
Is "as far away from any Land Rover product as I can get" anywhere near Kent?
If so, you are most welcome to pop over & get your codes cleared for free on my Hawkeye.
Let me know if I can help Thumbs Up Quis custodiet ipsos custodes?
15 MY 110 XS USW
54 FFRR Vogue TD6 Touchscreen - Gone!
56 FFRR TDV8 VSE - Gone!
Post #134115 2nd Aug 2012 8:55pm
Dolphinboy
It is probably water got into the ABS module and causing poor connection. This will cause all the other faults as all are on the same loop and a ABS fault stops the power getting to the other sensors, causing an alert.
It is easy to open the module and dry out with hair dryer then check for corrosion - 10 min job. It is situated to the rear of the engine near the bulkhead/windscreen.
Never power wash the engine!! There are too many electrical gubbins.
Post #134118 2nd Aug 2012 9:12pm
paneldamage
It could also be a sign of a tired battery- I presume you were cleaning car, lots of opening/closing doors, etc, and these kinds of error messages then pop up. My experience is that the car is sensitive to low batt voltages. The 15 min disconnect, followed by resetting the steering angle lock to lock should help.
Post #134132 2nd Aug 2012 10:43pm
jim2RRs
United States 2005 Range Rover HSE 4.4 V8 Chawton White
pricey for a small box.
Well, that's one way to look at it.
If it'll make you feel any better, I can send you a VERY LARGE cardboard box you can put the IIDTool in.
Alternatively, you could see what Blackbox Solutions charges for their magic box.
Then perhaps ring up the dealer and ask if you can buy the official Land Rover diagnostic machine.
And then jump online and buy the IID Tool in about 2 seconds. Jim
2000 NAS HSE
2005 NAS HSE
Post #134137 2nd Aug 2012 11:37pm
+1 what jim said..
blackbox faultmate costs around £1000, the IIDTool costs around £250 and then consider how much a dealer charges to reset your error codes . ... - .- -.
Post #134145 3rd Aug 2012 8:25am
piecost76
The Hawkeye is under £300 and is not VIN-tied so you could use it on any L322.
I have both a FFRR & a D3 so it suits me really well but I cannot currently write to the CCF. Personal preference as ever Thumbs Up
http://www.island-4x4.co.uk/diagnostic-too...-3574.html Quis custodiet ipsos custodes?
15 MY 110 XS USW
Post #134147 3rd Aug 2012 8:40am
ebajema
I suggest to have a good look at all your earth/ground connections as well as the clamps on the battery. Take them off, clean off any corrosion. On the battery clamps, put a thin coat of Vaseline to prevent future corrosion on the other connections use a proper electrical contact cleaner and if you don't have any, WD-40 also does a decent job just not as good as a good electrical contact cleaner. MY 2010 5.0 SC Galway green and sand interior!!
Post #134148 3rd Aug 2012 8:42am
Glideman
This morning I disconnected the battery. Took off the box which was under the windscreen & behind the battery & cleaned all the connections & applied some contact switch cleaner and then some silicone spray after drying it out. The plastic box was slightly open so that may have caused the leak into the connections.
Started the car & all the warning lights have gone out apart from the orange one in the middle of the clocks, think it's skid control. It still has HDC inactive & Suspension inactive but both seem to be working. Suppose it's time to break the piggy bank open again & buy a reset tool.
Thanks everyone for all the help with my car, the knowledge on here is great Thumbs Up Range Rover 4.4 V8 Vogue
Post #134179 3rd Aug 2012 12:10pm
Not forgetting rswsolutions RAC Tool (not tied to VIN) @ £160 but would take @ three weeks to get here from Denver! .
Post #134198 3rd Aug 2012 3:52pm
