Home > Maintenance & Mods (L322) > HDC, Air Suspension & hand brake and ABS light?
........plus shipping and maybe tax/customs charge TIM Wink ...... ... - .- -.
Post #134201 3rd Aug 2012 3:56pm
jim2RRs
United States 2005 Range Rover HSE 4.4 V8 Chawton White
I currently have the same fault.
According to IIDTool, right front ABS sensor fault.
I think the actual fault message was "You drove the vehicle on the street which caused the Right Front ABS sensor to fail. Your car will now pout and be fussy until you spend money on her. Go buy her something nice."
That might not be the exact fault message, but it's close.
I've ordered a replacement (30USD), which should arrive next week.
I'll have it installed on the weekend.
I know what you mean about the strange movements; since EAS is not "functional", it will LEAP to the setting it wants to see, none of the stately, graceful adjustment, just BANG! and it's there! Jim
2000 NAS HSE
2005 NAS HSE
Post #134231 3rd Aug 2012 7:44pm
Saint.v8
Location: UK< Surrey - Near the Middle Close to Some Green Bits
After you reconnected the battery did you reset the sterring angle sensor by turning full lock to full lock and back to centre again??
Post #134245 3rd Aug 2012 9:53pm
paneldamage
Wot Saint v8 said; the light/ message stops on till the steering is turned lock to lock.......
Post #134362 4th Aug 2012 9:44pm
Glideman
Location: Stood next to a broken down Range Rover in Darwen
United Kingdom 2003 Range Rover Vogue 4.4 V8 Zambezi Silver
Yes I reset the angle sensor but still get the sus inactive message & the HDC inactive messages. Range Rover 4.4 V8 Vogue
Post #134521 5th Aug 2012 8:09pm
Saint.v8
Time to plug it in and see what codes are showing....
Post #134586 6th Aug 2012 10:18am
jim2RRs
I replaced the right front ABS sensor this morning.
30 minutes total.
Jack up car, jack stand, remove road wheel.
disconnect connector, remove clips from cable, allen screw to remove sensor.
apply anti-seize grease to sensor (came with new sensor).
install.
replace road wheel, remove jack stand, lower vehicle.
drive.
All Better!!
$30 USD for the part.
no reset of anything was required, as the system checks for an error on startup.
Yay! Jim
2000 NAS HSE
2005 NAS HSE
Post #134984 8th Aug 2012 4:49pm
Saint.v8
Saint.v8 wrote:
Try disconnecting the battery waiting 15 minutes then reconnect...
Carryout the steering angle sensor reset by turning full lock to the left then full ock to the right then back to centre....
That may kick it back into action...
I had similar and it turned out to be a dodgy ABS sensor....
The ABS system in connected to the same data bus as the EAS....so a fault in the ABS system usualy freezes the EAS too (annoyingly).
The reason it knocks out the HDC & DSC too, is those two systems also use the ABS sensor information to maintain control down hills and to monitor the traction of all 4 wheels for the DSC.
Getting a diag tool is a fab plan
Wooohooo looks like I was right - do I win a prize???
Post #135372 10th Aug 2012 2:55pm
