![]() | Home > Technical (L322) > BATTERY DRAIN |
STEVE57 Member Since: 27 Apr 2012 Location: solihull Posts: 103 ![]() ![]() ![]() |
Brian GOG Member Since: 08 Dec 2011 Location: leeds Posts: 57 ![]() ![]() ![]() |
I just a slim screwdriver in the latches to put them in the latched position. Then you can just pulled the screwdriver back out to unlatch them just open the handle - sometimes you may have to apply abit of pressure on the claw mechanism if it's abit stiff. In theory locking the vehicle with the key disables the volumetrics eg: leaving the dog in the car. By doing both locking tests it allows you to elimate ( or identify )the volumetrics quickly. |
Brian
more info
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35836 ![]() ![]() |
could be the fsr [final stage resister]
nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3983 ![]() ![]() ![]() |
Fuse 52 serves the HEVAC ecu which also controls the heated seats.
[mod edit-no need to use the quote when replying ]
47p2 Member Since: 05 Oct 2010 Location: Gone Beyond, Subaru Posts: 8048 ![]() ![]() |
It is possible |
Not so much faulty but I don't think the manufacturing quality is particularly high.
ok, thanks will check fuse 12 2007 supercharged ,Cairns Blue with Navy & Parchment Interior |
Hi
dannyp15 Member Since: 21 Sep 2011 Location: essex Posts: 244 ![]() ![]() ![]() |
hi guys
hevac control module on fuse 52 and 34..have you pulled fuse 34 to see if it makes any difference.. ... - .- -.
