![]() | Home > Technical (L322) > Rear Passenger Window Stuck partially down |
Well this is great!
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35805 ![]() ![]() |
try and listen to see if the motor is working, if its whirring then the cable is broken or the window has become stuck on the runners...if you cant hear the motor then the motor is knackered or there's no power getting to it, either way the cards would have to come off.. ... - .- -.
No whirring noise there Stan |
before you do remove the card WILL, you could dis-connect/re-connect the battery and see if that reboots the bcu...and you have tried both the rear door switch and your drivers switch? ... - .- -.
Slam the door shut a couple of times then try the switch …. |
Tried both Stan |
Well door slam no worky and definately no motor action.
Stupid question Will but is the switch not just gubbed , i.e. change them over to see if that is the problem |
Will have to check later Mick as I've tried both drivers panel and the door panel one to see if i could get a response and there was no motor movement |
JustinP Member Since: 24 Oct 2010 Location: Cambridge Posts: 889 ![]() ![]() ![]() |
If you have the total closure enabled (hold remote lock button to close windows and sun roof) try that to rule out the switch.
Cheers Justin |
Well it's now working!!!
47p2 Member Since: 05 Oct 2010 Location: Gone Beyond, Subaru Posts: 8048 ![]() ![]() |
The problem is you let your FFRR know you were going away and it threw a hissy-fit |
